05 cluster swap
Old Nov 27, 2008
Guso's Avatar
Guso is an unknown quantity at this point
05 cluster swap
would it fit in a 98 ex? if so would there be any mods required?
Old Nov 27, 2008
Re: 05 cluster swap
i doubt it, the mounting is different and so are the connectors, so even if you got ahold of the wire diagrams and spliced wires, it physically would not fit in place like the old one. im not sure how you would get the lcd mileage display to work either.
Old Nov 27, 2008
Guso's Avatar
Re: 05 cluster swap
yeah makes sense. know of site where i can order some clean white reverse indiglo gauges? preferably with no cheesy off brand logo on them
Old Nov 28, 2008
Re: 05 cluster swap
autodynamic.com has some, ebay might too
Old Nov 28, 2008
Guso's Avatar
Re: 05 cluster swap
kk thanks!
Old Nov 28, 2008
Guso's Avatar
Re: 05 cluster swap
http://www.autodynamic.com/detail.as...=EGHC9600EA-S7
im going to get these. close enough to the cluster.. but no glowing red needles
Old Nov 28, 2008
Re: 05 cluster swap
yeah those were the latest style. i like em
Old Nov 30, 2008
mdawg's Avatar
mdawg is on a distinguished road
Re: 05 cluster swap
Thats what I have, they are ok...not nearly as good as the picture. I wouldn't mind selling you mine if your still interested for a bit cheaper. Just PM me. I'm in the process of trying to buy my friends accord so I wont be needing them.
Old Dec 1, 2008
Guso's Avatar
Re: 05 cluster swap
kk well let me kno if u do. u got time cuz im broke
Old Dec 10, 2008
mdawg's Avatar
Re: 05 cluster swap
Well here is a little rebirth, I pulled out my old diagrams and figured out how I had everything hooked up. If anyone has any ideas on how to get the Gear position to work that would be great. Still again the temp gauge will no work.
Old Dec 12, 2008
Guso's Avatar
Re: 05 cluster swap
so according to you its possible to wire it. but i have to give up my temp gauge. which wont break my heart. but will it fit was more of my question
Old Dec 12, 2008
mdawg's Avatar
Re: 05 cluster swap
Well like I said the fuel gauge is off a bit so you would have to figure out where its empty with your actual tank, but one it warms up a little and I can get back outside I'm going to see if putting a resistor in the line before it goes into the gauge will make the gauge read any lower to get it closer. Fitting will be tricky, If you cut the two bottom tabs then it should go in pretty good its just the bezel that your going to have to figure out cause the one for our car does not fit the cluster nor will the 03-05 bezel fit in our dash. Also here is an updated diagram I forgot to put the second ground wire on it.
Old Dec 14, 2008
Guso's Avatar
Re: 05 cluster swap
thanks man! appreciate it. im going to try and find a good deal on one and see what i can do. if i figure anything out il let u kno!
Old Dec 19, 2008
mdawg's Avatar
Re: 05 cluster swap
Alright hooked up a few things today. I just tapped into the wires of my current cluster and ran them from the dash so the new dash it just sitting in my seat right now. Only thing I have hooked up is power,ground,tach,spedo,and fuel. I'm uploading video now so hopefully it will be done by the time I go into work if not I'll post them later tonight.
Old Dec 19, 2008
mdawg's Avatar
Re: 05 cluster swap
Here they are
http://www.youtube.com/watch?v=-FPSbziUJY8
http://www.youtube.com/watch?v=YsKRqj5JEes
Old Dec 29, 2008
Guso's Avatar
Re: 05 cluster swap
dam man ur gauges u have in already look nice. nothing compared to the 05 tho. so it is possible. thanks guys!
Old Dec 29, 2008
Re: 05 cluster swap
nice!
Old Dec 29, 2008
DX5spd's Avatar
DX5spd is an unknown quantity at this point
Re: 05 cluster swap
Sweet Ive been wanting to do this for a while. Nice Info and diagram. Is there any way to get the temp gauge to work if not ill just get an aftermarket one. this is going on my mod list
Old Dec 30, 2008
mdawg's Avatar
Re: 05 cluster swap
Only thing I gotta test really is the constant 12v to see if the mileage will save. I also want to see if putting a resistor on the fuel wire will make it read less since the newer civics have a bigger tank.
runawaykinms
15
Mar 22, 2019 10:32 AM
fatih717171
Jul 25, 2016 06:22 PM
wingsfan19
Oct 1, 2015 03:45 AM
DatGuy_Robb
Sep 3, 2015 08:08 AM
fatih717171
Jul 8, 2015 12:14 AM
