D16 Tranny leaking tanny fluid HELP
Old Oct 13, 2008
Kirill615's Avatar
Kirill615 is an unknown quantity at this point
hey everyone, yesterday my clutch started slipping very bad as i powershifted. so i thought that my clutch gotten worned out, so i drove the car today around the block and when i pulled into the drive way the car was smoking. as i jacked up the car, i saw that the transmission oil was leaking out. the leak is coming from the seam where the transmission is bolted onto the engine. so my clutch wasn't slipping due to wearing out, but it was due to tranny oil being splashed all over the clutch assembly. however, my question is this, has this happen to anyone before? i'm going to be taking off the tranny tonight, but the question is this, will i have to replace my transmission or will i or a mechanic will be able to fix the leak somehow?
Old Oct 29, 2008
lilmidget08's Avatar
lilmidget08 has a reputation beyond reputelilmidget08 has a reputation beyond reputelilmidget08 has a reputation beyond reputelilmidget08 has a reputation beyond reputelilmidget08 has a reputation beyond reputelilmidget08 has a reputation beyond reputelilmidget08 has a reputation beyond reputelilmidget08 has a reputation beyond reputelilmidget08 has a reputation beyond reputelilmidget08 has a reputation beyond reputelilmidget08 has a reputation beyond repute
Re: D16 Tranny leaking tanny fluid HELP
depends on whats leaking.
Old Nov 2, 2008
sql_civic's Avatar
Are you sure it's tranny fluid and not motor oil? If it's motor oil then you'll need to replace the main seal.
Vaguexo
Jun 13, 2015 04:11 AM
MajTom
Jun 2, 2015 11:48 AM
usajags84
May 30, 2015 06:49 PM
dosmastr
May 5, 2015 12:19 PM
bsmiley
Apr 27, 2015 01:27 PM
