97 civic problems
Old Jul 10, 2007
Ctrl Alt D L33t's Avatar
Ctrl Alt D L33t is an unknown quantity at this point
97 civic problems
Hello guys, im new and im just posting this for my brother. He drove home today from work & was leaving later on and when he puts the key in the ignition everything has power going to it except the engine want even turn over @ All.. Could this problem be in the Starter? Connections/Ground? This car has ran perfect for the past 2 months since he has had it...
Anyone have any idea or does this sound like it needs a new starter the one on there now looks pretty old..
THANKS FOR YOUR TIME & ANY HELP U CAN PROVIDE!
Old Aug 19, 2007
juan_p__m's Avatar
juan_p__m is an unknown quantity at this point
Re: 97 civic problems
I did not understand. Do you see the engine turn over? Do you hear the starter spin? Do you hear the starter click?
Old Aug 23, 2007
sql_civic's Avatar
Yup, it could be the starter, power connections, ground connections, or a dead battery, busted ignition switch, bad main relay, blown fuse, etc.
Old Sep 9, 2007
horent135's Avatar
horent135 is an unknown quantity at this point
it mostly dead battery or bad starter. but check the battery first cuz it the easiest and cheapest repair job.
Old Sep 15, 2007
BoneStOck_176's Avatar
BoneStOck_176 is an unknown quantity at this point
my friends accord has the same problem... if you can get it started by giving it a battery boost then it probably is the battery.. i agree with horent just get the battery checked out otherwise change the starter buddy!
Old Jan 23, 2008
mauricio_m's Avatar
mauricio_m is an unknown quantity at this point
The problem is a connector that goes to the starter, it trends to get loose with the vibrations. I had the same problem, the engine wasn't cranking but the beam lights were OK. I reconnect this connector and everything went OK up to now. The starter is located below the distributor close to the gear box and the connector is a flat metal one covered by a rubber cap.
Xuhme
21
Aug 7, 2023 03:40 PM
CarStuff
Dec 6, 2020 12:52 PM
Braun
Apr 23, 2015 09:03 PM
dooner24
Apr 14, 2015 07:51 PM
NoToRiOuSxPiNoY
Bolt-on Engine Performance
Nov 7, 2001 11:19 PM
