H22?
Old Jan 30, 2004
hondacivicd17's Avatar
hondacivicd17 is an unknown quantity at this point
H22?
Anyone know any information on swapping an H22 in a 95 civic hatch SI? I need to know the differences in installing it compared to a b series swap? How much harder is the wiring?
Old Jan 30, 2004
kjgracing's Avatar
Hail to the king baby
kjgracing will become famous soon enoughkjgracing will become famous soon enough
IBTL
Old Jan 31, 2004
ASuave's Avatar
ASuave is an unknown quantity at this point
haha, ibtl? this is previous gen civics
as far as the h22, i wouldn't do it. its heavier than the b-series and will cause the hatch to be too front heavy, thus causing problems with handling. i've heard that this can be solved by using accord shocks and springs to hold the weight, but never seen it done or the results (or if it actually works for that matter). imo stick with a b-series
Old Feb 3, 2004
Rionmann3's Avatar
Rionmann3 is an unknown quantity at this point
It would be better to stick with the b-seris. I would recommend a B16a, but if you still want the h22 here is a good site with nice prices: www.nippon-motors.com
Old Feb 4, 2004
why do you recommend the b16a?
Old Feb 4, 2004
Green Civic's Avatar
A H22 in a 5th gen civic is very tough. The engine bay is a little smaller than the 6th gen. I'm not sure if engine mounts are available for a h22 in a 5th gen. It would work in a 6th gen however. A b-series would be the way to go.
Old Feb 4, 2004
Rionmann3's Avatar
Stupid me i meant a B18 engine
Old Feb 5, 2004
Gryphin's Avatar
00 Hatchback Owner
forget these haters, h22 in a hatchy runs 12's, if tuned right.. so i say go for it, its just as hard as the b18 or any other engine, if you take it to people who do swaps alot, it wont be that hard...cost you about 1500 to swap the engine...
Old Feb 5, 2004
Rionmann3's Avatar
$1500??? So where did you find a H22 engine for 1500?
Old Feb 5, 2004
Gryphin's Avatar
00 Hatchback Owner
not the engine! install...engine cost about 2000-2500...
Old Feb 5, 2004
PunkingCivic's Avatar
I need TP for my bunghole
Yah the h22 will fit
http://www.hasport.com/Products/Mounts.htm
http://www.hasport.com/Products/Moun...unt%20EGH1.htm
here is a 93 hatch with a h22a j-spec motor
http://www.fastandfuriouseast.com/ga...fault_sub1.htm
Old Feb 5, 2004
Rionmann3's Avatar
Well actually you can find an h22 with the ecu and tranny for 2100 at nippon motors website, but yeah i know the installation will cost 1500...
Old Feb 25, 2004
RacerSlashRicer's Avatar
RacerSlashRicer is an unknown quantity at this point
hell yeah! did you see that car is ht.com the crx with the h22a, dayum that car kicks serious ***. i asked him if it had the MASSIVE UNdersteer like you all though in a crx, but it apparently handles just fine. but i would not go to extreme lengths trying to get the car to handle perfectly cuz its only great for straight lines. btw i have an h22a for sale from my wrecked 2001 prelude. pm me for info $2000 firm. or i may just put that in my crx like 2point2 did on ht.com.
Old Feb 29, 2004
Merciless's Avatar
Merciless is an unknown quantity at this point
As someone else said H22A ownz if you want to go in a striaght line. But if you want the cornering ablitiy then go with a B18 or B16 also if money is a issue then go with a B18B Turbo set up that will run you cheaper than a H22A and you will be pushing around 240whp at 7-8psi.
Here in Tempe AZ SRD will do the complete swap fully installed for 5Gs that is with a Front mount. if you go h22a though you will have a TQ advantage and TQ is a very good deal if you want a 1/4 car well....TQ is just good all around I guess.
Old Mar 9, 2004
i just dont like the 75x90mm stroke of the d16 motors. i dont believe you can rev those very high with the r/s ratio it has, i am starting not to like my ls motor for the followng reasons, 81x89 stroke. yeah, i shoud have gotten a b18c with vtec
ttamrekab
Sep 28, 2015 01:22 AM
ttamrekab
Sep 25, 2015 04:41 PM
ttamrekab
Aug 23, 2015 07:45 PM
DJayG
Engine Swaps
Aug 27, 2005 01:48 PM
2k4ex
Aug 30, 2004 10:41 PM
