Fuel efficiency problem
Rep Power: 0 Fuel efficiency problem
Hi guys
I recently bought a Honda Civic 2001 because I was sick and tired of putting 20$ of gas a day in my Grand Vitara SUV.
I bought the Civic for really cheap and I changed a lot of parts on it..transmission, exhaust manifold, brakes etc...
In the first 100 km that I did with this car, it took like 14 liters of gas. Is this normal? What do you guys recommend? I checked my tires and they are fine. The only thing that I haven't checked yet is the spark plugs. Do you think that they make that much of a difference in fuel economy?
Thank you very much for the help, it is really appreciated!
Re: Fuel efficiency problem
Thats the equivalent of around 17 mpg....only way that might be normal is if you were driving like a maniac, i average around 30.
Rep Power: 0 Re: Fuel efficiency problem
Live for the Twisties
Rep Power: 260 Re: Fuel efficiency problem
It's cold in Ottawa, so longer warm up times combined with winter blend gas affects fuel economy a bit, not that much though. Is your air filter good, cat functioning, no 02 sensor codes?
I haven't checked my air filter yet.
The air filter has a huge impact on mileage, pick one up asap, I would change the spark plugs as well, that's one of the first things I do after purchasing any used car. Reset the idle as well since you've done quite a bit of recent work, that might help a bit.
https://www.civicforums.com/forums/1...reset-ecu.html
That Dude with the Questions
Rep Power: 174 Re: Fuel efficiency problem
My sister filled up 37 liters in my car today. It had only been driven 400 km :S My tires are a little big, so it's reading slow but not by that much!
Thats 10 km per liter. Not so good! Maybe once I change my filter it'll make a big difference..
Well you said it only seems to go down when the car has been sitting and then started, I would check for fuel leakage around the tank and lines etc.
Rep Power: 232 Re: Fuel efficiency problem
if your going by the fuel gauge your probably way off hondas are notorious for having fuel gauge inaccuracies. but definitely do a tune up plugs,air filter,oil change.
Rep Power: 174 Thread
CarStuff
12-06-2020 12:52 PM
WaryDriver
05-27-2015 05:54 AM
mrcell24
05-19-2015 10:02 AM
8th, affects, civic, consumption, econnomy, efficiency, em2, fuel, gas, generation, honda, mileage, poor, problem, problems
