Soon to be 01 Civic owner questions
Soon to be new Honda owner
I'm buying a 2001 Civic at the end of the month, its burgundy a southern car and in really good shape. Can't wait to replace my current 95 Toyota Tercel which is literally falling apart.
I'm buying an 01 civic lx at the end of the month in remarkably good shape. My main question is aside from the recalls one of which still needs to be done is there any area of the car I need to really look at or keep an eye on, mechanical fail points & rust/rot zones, I live in the rust belt and want to address the issue before it can start. Also is there an oem remote car starter for the car I can install or do i have to go after market?
Thanks
Thanks
Re: Soon to be 01 Civic owner questions
It's mileage is 160k, automatic transmission, All the service was done including tuneups except for the last recall because it was in storage during deployment, but went back on the road about 6-8 months ago. The owner is being re-stationed at the end of the month and wants to purchase a newer used car in the new area outside of the rust belt.
An ATF drain and fill is most likely due (over-due). Unfortunately, the automatic transmissions in years '01-'03 are know to have issues. Find out if the transmission has been rebuilt or replaced.
keep an eye on coolant reservoir levels, radiator fan performance, and engine temp gauge readings. These engines aren't technically prone to overheating, but if something does cause an overheat, they are prone to gasket failure and head warpage. things like radiator cracks, hose cracks, fan failure, and sticky thermostats can be all it takes to make the temp climb and gasket break. It can be an expensive bill to pay if you're paying a mechanic to do it.
Thanks
Thanks
Also if it is possible , get an Engine diagnostics test done
Best of luck with your buy!
