01 Civic cuts off but restarts after a few mins.
Old Nov 14, 2016
bhcjr's Avatar
bhcjr is an unknown quantity at this point
I have a 01 Honda Civic where I had the radiator,water pump, serpentine belt, thermostat, temperature sensor replaced and above all, head gasket and overhaul of the heads. After driving for a few weeks one day all of a sudden my Civic shuts off. After waiting a few moments It starts but drove sluggish. I turn off vehicle and wait ten minutes and it started to where I drove 15 miles without no problem to my distination. I have had the same issue again afterwards but it didn' drive sluggish. Could it be my timing belt sensor or fuel pump?
Old Nov 14, 2016
Re: 01 Civic cuts off but restarts after a few mins.
Got CEL on? Got codes?
Old Nov 14, 2016
bhcjr's Avatar
The last code I got read a leak at the Evap canisters . I haven't got an up to date read to this day. What's a CEL?
Thank you.
Old Nov 14, 2016
Originally Posted by bhcjr
What's a CEL?
Check Engine Light
Old Nov 14, 2016
bhcjr's Avatar
Originally Posted by ezone
Check Engine Light
Ok...yes. the last read was a leak in Evap canister area.
Old Nov 14, 2016
Ok, check for any new fault codes since this new problem began....
Old Nov 15, 2016
OneJzSupra's Avatar
OneJzSupra is an unknown quantity at this point
I had this happen to me before.... I had zero check engine lights and would start replacing stuff thinking that would help the issue. Then one day after it happened I disconnected the battery and reconnected it and noticed that it fired right up. That led me to talking to a Honda tech and he basically told me that with this generation Civic he has seen a few cases of water causing damage to the ECU. I purchased a used ECU on Ebay and had a friend tow me to Honda to sync the alarm system and she fired right up.
Old Nov 17, 2016
bhcjr's Avatar
Here's the codes.
P0420, P1361, P0325, P1457
Old Nov 17, 2016
Here's the codes.
P0420, Catalytic converter efficiency
P1361, Cam position sensor intermittent
P0325, Knock sensor circuit
P1457, EVAP system leak (canister system)
Cam sensor code is the likely cause your new symptoms.
Old Nov 17, 2016
bhcjr's Avatar
According to the manual there are two sensors...CMP and CKP
Old Nov 17, 2016
bhcjr's Avatar
Ok...I did a little research. It's the CMP sensor . I think I'll get a quote on the sensor and install myself before it gets cold. I'll get back to you and thank you ezone.
Old Nov 17, 2016
Cam position sensor is CMP.
Make sure its connector is fully plugged in.
KNock sensor code doesn't help but I don't think it will cause it to stall out.
Old Dec 19, 2016
bhcjr's Avatar
After my last Comment my Civic had a bad oil leak . I've looked but have no clue where the leak is at . I mean the leak is bad . Left a big puddel of oil. Driver side wheel has indications of where the leak may be. Besides having a bad gasket(s) what other areas can there be oil coming out?
Old Dec 20, 2016
How many miles on the engine? 150k-200k?
Valve cover gasket?
front crank and cam seals?
Oil pump need resealed?
Old Dec 20, 2016
bhcjr's Avatar
There's a leak where the crank and cam area.
Old Dec 20, 2016
bhcjr's Avatar
Could my last service could've been done half ***? I only got less than 3 k miles after my last head resurfaced and head gasket replaced.
Old Dec 20, 2016
Take stuff apart so you can see the leak?
