Can anyone identify the headlights on this civic?
Old Mar 21, 2016
05EX's Avatar
05EX is an unknown quantity at this point
Question Can anyone identify the headlights on this civic?
Size:  135.6 KBhttps://i.imgur.com/T1jOwex.jpg
Old Mar 22, 2016
Poopies's Avatar
Super Moderator
Re: Can anyone identify the headlights on this civic?
There are a lot like that. Why do you want to know?
Old Mar 22, 2016
05EX's Avatar
I am looking to put either those or similar ones onto my civic
Old Mar 22, 2016
mcnoople's Avatar
The legs in the public bathroom stall
mcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to behold
Many of the web purchased projector housings are known to have inferior/bad light output. A dead giveaway to run from any listings of these style of headlamp is if the ad states that it can use both a halogen and a HID bulb. If you do go with this style of headlamp for the appearance factor you may still need to replace the actual projector inside the housing with a well made projector if you want a good amount of light output.
Another issue I have read about with housings such as you have pictured is that they frequently do not have proper UV protection. This means that in 2 years they might be completely hazed and faded in some enviroments. Another option if you are handy with tools is to install your own HID projectors into your OEM housings. This gives you lights optics of known quality and if properly done you can have better forward lighting than 99% of the cars on the road.
Of course I should put out this disclaimer. Retrofitting projectors is technically illegal. So is installing housings bought off of the internet. Many companies will claim DOT approval of their products without actually going through the certification process. Personally I would go with a retrofit. It is the only way to have superb output with proper focusing and control of the light. Properly done projectors will light up the road while causing little to no glare to oncoming traffic. Here is a link to what is properly the best site about retrofitting on the web.
http://www.hidplanet.com/forums/
Old Mar 29, 2016
Pier7866's Avatar
Pier7866 is an unknown quantity at this point
Originally Posted by 05EX
It look to me like these are original head lights or may be after market that were retrofit with the projector and smoked out. To retrofit there are certain companies that do that but its expensive online or ebay for say there is a lot of variety of projector headlamps with different pricings you just have to find out if they do have a quality projectors in them. Otherwise you can order retrofit. Hope this help.
Old Mar 29, 2016
Poopies's Avatar
Super Moderator
[QUOTE=Pier7866;4705026To retrofit there are certain companies that do that but its expensive online or ebay for say there is a lot of variety of projector headlamps with different pricings you just have to find out if they do have a quality projectors in them. Otherwise you can order retrofit. Hope this help.[/QUOTE]
When I retrofitted mine ('03, so single-beam headlights ) I went to theretrofitsource.com . They have some awesome stuff there, and the install was relatively simple. I got mine on Thanksgiving so it was 25% off.
Old Jul 6, 2016
johnlam1688's Avatar
johnlam1688 is an unknown quantity at this point
They only sell the projector inside. Not the headlight. This look like some one bake the head light apart and install the whole projector unit.
Old Jul 6, 2016
Definitely looks like someone retro'd some oem headlights and painted them. ebay prolly has a bunch that look similar if you just want the look
Shadymilkman129
May 20, 2012 11:45 PM
