Timing belt on 04 Civic
Old Jan 3, 2016
chi_tea's Avatar
chi_tea is an unknown quantity at this point
I have just purchased a 04 Civic VP from a dealership and I am not sure if the timing has been replaced. The car did not come with a manual, but according to a PDF from Honda website it provides no information about the maintenance on timing belt.
It currently has 145000miles on it.
I have also grabbed CARFAX and AUTOCHECK reports but all it shows is oil change/renew/inspection and nothing about detailed maintenance.
Can someone advice me if the timing belt needs to be changed? Does it seems like it has already been replaced?
Thank you in adnvace!
Old Jan 3, 2016
Re: Timing belt on 04 Civic
Are you a gambler? Win every time?
A losing gamble on this one could cost you a bunch of valves --or an engine.
If there is any question about its history, the timing belt should be replaced....along with the tensioner---NO AFTERMARKET on that part. Factory only on the tensioner and spring set.
Old Jan 3, 2016
chi_tea's Avatar
So I should replace it ASAP?
What should be replaced? Timing belt + water pump + tensioner?
Old Jan 3, 2016
At 150k I'd suggest all those plus the pair of accessory belts. If there is any evidence of oil leakage I'd put in cam and front crank seals too. And valve cover gasket set.
Old Jan 5, 2016
mikey1's Avatar
if there is any doubt whatsoever i would replace it ASAP
Old Jan 5, 2016
chi_tea's Avatar
Thanks very much for all your inputs! I'm going to get it replaced as soon as possible at the dealership.
emich
Aug 26, 2015 08:09 AM
0396
Aug 21, 2015 05:27 PM
WaryDriver
Aug 16, 2015 11:22 AM
bugginb
Detailing
Nov 3, 2001 08:36 PM
