Reverb Cluster
Reverb Cluster
So I found a guy parting out an '04 reverb locally. I'm just wondering if the reverb cluster is simply pnp into an '04 dx sedan and if there's going to be any lights emitted due to differences in features if any?
If nobody knows I'll probably check it out and test fit it next week n let you guys know.
I'm also kind of curious if the reverb coupe rear lip will fit on the sedan too. I've always gotten mixed infos on fittings so I'll probably test fit that too n snap some pics while im at it.
Re: Reverb Cluster
Cluster gauges should basically work, but there can be differences with SRS systems that may leave the idiot light(s) on. IDK what else might be affected.
The catalog lists some 15 or more different cluster choices for various model versions.
Odometer mileage stays in the cluster, so the new will read whatever the other car had.
Re: Reverb Cluster
I've got a Reverb. I far as I can tell the only difference between a Reverb and a DX is, with the Reverb, you get the 6-disk CD changer stock and the aero kit around the bottom of the car. Other than that, pretty much identical vehicle. They didn't even put premium speakers in the Reverb; you would think it would at least have a good sound system given the name. I've even had to swap the cd changer to a Kenwood system since the damn cds kept skipping and it doesn't have USB. When I look for parts, I always refer to a DX and I have never had a problem.
I've got a manual, so my cluster has the large tach on the left and small temp gauge, spedo on the right with small gas gauge in the right corner. Odometer in the spedo gauge at the bottom.
fatih717171
Jul 25, 2016 06:22 PM
hondacivic0253
Sep 29, 2015 08:06 AM
260000milesgoal
Sep 25, 2015 07:41 PM
rayman009
Sep 12, 2015 08:30 PM
Bricoleur
Sep 9, 2015 12:23 PM
