bmxa question
Old Nov 2, 2014
rezsst's Avatar
rezsst is an unknown quantity at this point
bmxa question
can someone tell what line would be the pressure line. just installed a reman bxma and going to install a cooler n filter, just want to make sure i get things right. or a link
thanks
Old Nov 2, 2014
Re: bmxa question
Off the top of my head:
When we get a factory reman trans for a 7th gen, there is a filter that comes with it to be installed in the line between the drivers side radiator fitting and the trans, and it is intended to catch any failure debris that was trapped in the cooler so it doesn't harm the new trans.
That would make the drivers side of the radiator trans cooler the return side and the pass. side the pressure side. (As long as nobody got the lines switched backwards at the trans.)
Does that help?
Old Nov 2, 2014
rezsst's Avatar
Re: bmxa question
you are my hero, thanks. can i ask you another question?
Old Nov 2, 2014
Re: bmxa question
For a dollar!
Old Nov 2, 2014
rezsst's Avatar
Re: bmxa question
has helpfull as you are i'll give you twenty. ok two questions. wait twenty questions. pressure line to new cooler to stock cooler then filter?
also droped tranny out from bottom had to remove sub frame, replacing lower control arms (bad bushing) and motor mounts. tie rods are good. i'm asuming i need an alignment but not sure. spindals are out
Old Nov 2, 2014
rezsst's Avatar
Re: bmxa question
here's some bikes to look at xs650chopper.com
Old Nov 2, 2014
Re: bmxa question
Depends on what you want done to the fluid.
The stock cooler also designed to act as a fluid warmer since it picks up heat from hot antifreeze to help the trans warm up faster (the trans can take a lot longer to warm up than the engine does).
You gonna tow a boat or anything?
On Pilots and Odysseys that got a Honda accessory trailer hitch and cooler kit, the path is:
Trans --> new cooler --> radiator --> trans
Then on yours I'd stick the filter in there like
Trans --> new cooler --> radiator --> filter --> trans
Since you got it that far apart, I'd definitely align it.
HTH
Old Nov 2, 2014
rezsst's Avatar
Re: bmxa question
great advice thanks.
so what do you think of the bikes
Old Nov 2, 2014
Re: bmxa question
Nice! There's more than a couple guys around my town that ride chopped metrics
robjcivic
Mar 12, 2017 12:10 PM
JMKendrick
Sep 16, 2015 06:17 PM
Bricoleur
Sep 9, 2015 12:23 PM
vImpostor
Vancouver
Sep 8, 2015 08:08 PM
junkyardguy
Sep 2, 2015 06:07 PM
