worried need help civic 1.6
Old Sep 14, 2014
sexysam777's Avatar
sexysam777 is an unknown quantity at this point
hi iv had my honda civic 1.6 2003 for 4 years but iv recently having a problem my temperature stays half way and the fans do not work what can cause this also when i park up i can hear sizzling water and steam from rad cap area i think my rad cap is an after market not genuine can that casue it ? hope someone can help thank you
Old Sep 14, 2014
rezsst's Avatar
rezsst is an unknown quantity at this point
Re: worried need help civic 1.6
Dont add water. You can buy a coolant mix tester for about $3 at any auto store when you buy a new cap. Good to make sure your coolant mix is correct. Temp half way is ok, when its in the red you have a problem. You should check the thermostat too. Check the fans too. Refer to service manual for testing. One of the experts will have more advice. Hope this helps
Old Sep 14, 2014
mikey1's Avatar
i agree never add water,
but you should never use coolant from "any auto store', these engines require honda OEM 'blue" premixed coolant, nothing else should ever be used
Old Sep 14, 2014
rezsst's Avatar
http://www.cb7tuner.com/vbb//showthread.php?t=191333
mattdoc
Mar 14, 2017 12:10 PM
Pr0n1s
Apr 30, 2015 03:08 PM
Tybonater
Apr 24, 2015 07:03 PM
jonavin
73
Oct 4, 2004 07:18 PM
ZSKCivic01
Nov 4, 2001 08:47 PM
