Help Choicing Clutch
Old Apr 13, 2014
tunedx's Avatar
tunedx is an unknown quantity at this point
What clutch do u guys recommend to replace the oem? I have 250,000km and torn between Sachs, Exedy, Luk, Beck and Arnley. Also do u recommend replacing the flywheel, resurfacing it or just using some emery cloth if it doesn't have any major scatches or deep grooves in it?
Old Apr 13, 2014
mikey1's Avatar
Re: Help Choicing Clutch
stock OEM clutch, nothing else will be any better
Old Apr 13, 2014
tunedx's Avatar
Which clutch best suits oem? Exedy, Luk, Beck and Arnley or Sach? I don't wanna buy from Honda...
Old Apr 13, 2014
Exedy OEM replacement will do you fine. It'll be much cheaper than a dealership.
Mikey, I'm assuming you mean "stock replacement, but not necessarily a stock Honda OEM clutch," right? Otherwise, I'd have to disagree. That would be like saying OEM brake pads > everything else.
Old Apr 13, 2014
GolNat's Avatar
Prelude Owner
Go with Exedy OE replacement.
If the flywheel can be resurfaced then it should be. If its beyond resurfacing then replace. Great time to put in a lightweight flywheel!
Old Apr 13, 2014
tunedx's Avatar
Anyone heard of Sachs or Luk clutches?
Old Apr 13, 2014
tunedx's Avatar
I know its generally rule of thumb to get flywheel resurfaced upon clutch replacement. I'm at 250,000km and if the flywheel doesn't have any visible groves or deep scratches is it still required to get it resurfaced? I was just going to clean it up with emery cloth if it didn't look too bad....
Old Apr 13, 2014
never heard of those two brands
As far as the resurfacing goes, though...
I'd take it to a shop to get it looked at, at the very least. They'll tell you if they need to resurface it or not. Worst case scenario, they resurface it and it's another $30 out of your pocket.
Old Apr 14, 2014
kinakoes2's Avatar
*watches temp gauge like a hawkboss* :D
kinakoes2 is a glorious beacon of lightkinakoes2 is a glorious beacon of lightkinakoes2 is a glorious beacon of lightkinakoes2 is a glorious beacon of lightkinakoes2 is a glorious beacon of light
Sachs is the same company as ZF, the transmission manufacturer... German, so if it's made in Germany, you can bet it conforms to TÜV standard, which insures you get pretty well-engineered parts, if not always cheap. ... however I'd make sure it's the same Sachs before plunking down your grip.
LuK is also a German company, so if made in Germany, TÜV applies (not if it's made elsewhere, though). No idea on fitment... but in general German parts go best with German cars. May need to seek a more firsthand bit of advice though.
Old Apr 15, 2014
hyperhonda2k2's Avatar
Tempus Fugit
hyperhonda2k2 is an unknown quantity at this point
i have the exedy stage 3 clutch and i like it, there is however noise from the clutch but not a whole lot, grip is good and engages great
curaze
Sep 22, 2015 08:27 AM
powman02
Sep 15, 2015 07:38 PM
rayaan_wasty
Sep 14, 2015 02:00 PM
Klame9420
Sep 7, 2015 10:03 PM
tommycanada
Sep 5, 2015 04:59 PM
