Can I stop my auto trans shifter from going into neutral when it's on drive?
Old Sep 2, 2013
tide55's Avatar
tide55 is an unknown quantity at this point
2004 Civic EX, Automatic Transmission.
When I put the shifter in D if I push forward on stick it will go into N. I assume this is intended and I didn't think much about it until I accidentally hit it. I'm concerned now a pet or someone might do it at some point when I'm on the highway. Probably unfounded but still.
Is there any way to make sure the shifter only goes forward into N by depressing the lock on the shifter? Or is there no way for safety reasons (eg the accelerator gets stuck or something)?
Thanks
Old Sep 2, 2013
rustycivic's Avatar
rustycivic is on a distinguished road
Re: Can I stop my auto trans shifter from going into neutral when it's on drive?
Even if you push it into neutral on the highway, nothing bad will happen......I've hit it before. The engine might rev a bit, but its not like you are manually shifting down to 2nd gear at 70mph or anything bad.
Old Sep 2, 2013
It is made this way.
IDK why, but it just is.
Old Sep 10, 2013
chozobody's Avatar
chozobody is an unknown quantity at this point
It's also a safety feature. Remember how Toyota had those "stuck" accelerator problems? If your accelerator got stuck for whatever reason, you could shift into neutral from any gear, which would allow you to coast without accelerating so you don't end up killing yourself. Unless you have a pretty big dog thats freaking out in the front seat, I wouldn't worry about it very much. Just don't drive around with your hand on the shifter either.
Old Sep 25, 2013
awdcivic2's Avatar
awdcivic2 is an unknown quantity at this point
yep aint gonna hurt anything to shift into neutral i mean unless you bounce it off the rev limiter for like 2 minutes lol.
Old Sep 29, 2013
civicbyrc's Avatar
civicbyrc is an unknown quantity at this point
its the same on all makes and models.
Xuhme
21
Aug 7, 2023 03:40 PM
jbradley4809
Apr 7, 2017 04:23 AM
davidpaustin
Apr 29, 2015 02:23 PM
tylerginevan
Apr 27, 2015 12:29 PM
smmahan
Apr 15, 2015 08:17 PM
