led light conversion
Old Jul 23, 2013
jringo8769's Avatar
jringo8769 should not be trusted
I would like to know if anyone has ever changed all the bulbs to led bulbs, and if they worked. Many thanks.
John
Old Jul 23, 2013
Re: led light conversion
I have. They work. You need to change your flasher unit unless you want hyperflashing turn signals. Either that or install load resistors on each turn signal you replace.
Also, your cruise control won't work unless you either a) install a load resistor across at least one brake light, or b) install a resistor inside the cruise control module.
Old Apr 27, 2018
Shay_G's Avatar
Shay_G is an unknown quantity at this point
I have. They work. You need to change your flasher unit unless you want hyperflashing turn signals. Either that or install load resistors on each turn signal you replace.Also, your cruise control won't work unless you either a) install a load resistor across at least one brake light, or b) install a resistor inside the cruise control module.
i have 7443 bulb (brake light and running light in the same bulb)
when you say "brake light" your mean running light or actually the brake light wires?
Old Apr 27, 2018
Install the load resistor in the brake light circuit wiring itself (wired in parallel with any brake light bulb)
themechanic
Lighting
Feb 2, 2018 09:23 PM
MamaBear2015
May 27, 2015 12:04 PM
eorlando1
May 17, 2015 11:16 AM
Broadbeb
May 14, 2015 09:49 PM
blackbullet
Dec 1, 2001 03:44 PM
