idler becomes higher
Old Oct 3, 2012
leosar's Avatar
leosar is an unknown quantity at this point
hi
i just changed the air filter for my honda civc 2004 and the idler runing becomes higher
how can i adjust it and is it safe to keep it like that
thanks
Old Oct 3, 2012
lowlife9's Avatar
Re: idler becomes higher
try reseting the ECU.
Old Oct 3, 2012
Just how high is the idle?
Do an idle learn.
Old Oct 3, 2012
lowlife9's Avatar
if reseting the ECU doesn't help try cleaning the IACV and throttle body.
Old Oct 3, 2012
leosar's Avatar
sorry,but can you explain to me how to do this
Old Oct 3, 2012
sl33pyriceboi's Avatar
two ways:
1. pull the ECU fuse (i think thats what its called) in your fuse box in the engine bay.
2. jsut disconnect the battery for a few mins.
note: everythign will reset. if you have a stock radio, make sure you have your radio code first.
Old Oct 3, 2012
here are the instructions from the intake FAQ:
Originally Posted by TRIZ
FAQ - The ultimate Intake FAQ – Intake questions and answers here!!!
Should I do an idle relearn after I’m done installing?
Sure, you changed the way it sucks up air so its probably sucking air at a different rate- good idea. To do this disconnect your battery for 10 mins, reconnect and start your car. Make sure nothing is running (fans, radio, accessories, headlights) and leave the car alone for 5-10 minutes without blipping the gas pedal. Turn off, restart and drive around- enjoy your intake.
Old Oct 3, 2012
leosar's Avatar
thank you very much
i wil do that tomorrow morning
Old Oct 4, 2012
leosar's Avatar
thank you guys ,did it ,fixed
Old Oct 4, 2012
palsana's Avatar
palsana is an unknown quantity at this point
If your transmission is bad and when you start your rpms rush to 3000rpms with out putting a foot on the gas pedal? what does it mean?
Would you think idle relearn would work?
Old Oct 5, 2012
why dont you give it a try and see?
solarpunk70
Apr 12, 2016 11:43 AM
Bruce2
Sep 27, 2015 08:45 PM
NROD315
Sep 23, 2015 03:46 PM
rayman009
Sep 12, 2015 08:30 PM
Donahue
Sep 8, 2015 10:43 AM
