What pulleys does 7th gens have?
Old Jun 19, 2012
Civicnoobie's Avatar
I am Epic
Civicnoobie should not be trustedCivicnoobie should not be trustedCivicnoobie should not be trustedCivicnoobie should not be trusted
And how often should you replace them?
Old Jun 19, 2012
sl33pyriceboi's Avatar
Re: What pulleys does 7th gens have?
You replace it when you flush your vtec fluid... Which should roughly be 100k
Old Jun 19, 2012
mac25's Avatar
Dr Krieger of Modification
sleepy are you using the honda oem vtec fluid or megnaoil's full synthetic high milage vtec fluid?
does it still "kick" in?
Old Jun 19, 2012
Hensinger2010's Avatar
Meh...
Hensinger2010 will become famous soon enough
just the conventional fluid for my vtec think i need a new reservoir tho :/
Old Jun 19, 2012
Aetoc's Avatar
Aetoc will become famous soon enoughAetoc will become famous soon enough
That's exactly why i don't use the vee tak...too much maintenance involved. The synthetic stuff is like $50 a quart.
Old Jun 19, 2012
I use the oem vtec fluid. It's pretty cheap at my local honda stealership since I have a friend that works there.
It's still expensive as hell. That's why I don't go over 4k rpms.
Old Jun 19, 2012
Kennykid2002's Avatar
Kenny the Ricer
Drain and fill, not flush. Especially not with synthetic.
Remember to clean the VTEC solenoid's filter after. People always forget to clean it.
Old Jun 19, 2012
MelJ's Avatar
Trance Addict
Muffler bearings are also highly overlooked. How do you guys constantly forget those?
Old Jun 19, 2012
Aetoc's Avatar
You have a point. They should actually be changed at the same time, as on most models with VTEC, the muffler bearings are lubricated with the same fluid, and therefore increase the frequency at which you should replace the vtec filter.
Old Jun 19, 2012
pjb3's Avatar
pjb3 is a glorious beacon of lightpjb3 is a glorious beacon of lightpjb3 is a glorious beacon of lightpjb3 is a glorious beacon of lightpjb3 is a glorious beacon of lightpjb3 is a glorious beacon of light
The only pulley that normally needs replacing on an engine is the harmonic balancer. The harmonic balancer usually has a rubber component to isolate vibrations and this can break down over time. I would think this would be examined when the timing belt is done and replaced if necessary. Since the one for the Civic is in $40 range I could see where some may do it with the timing belt just to be safe.
Old Jun 19, 2012
Muirsy's Avatar
Muirsy is a jewel in the roughMuirsy is a jewel in the roughMuirsy is a jewel in the roughMuirsy is a jewel in the rough
can't believe you all forgot about halogen fluid!
Old Jun 19, 2012
Kenny the Ricer
I think because most of us switched to Xenon fluid
Old Jun 20, 2012
Meh...
stumbled upon some 50/50 vtec fluid ended up warping all my rotor bearings :/ stick with the synthetic! youll regret it if you dont
Old Jun 20, 2012
aw, dude.. 50/50 vtec fluid is crap.. You shoulda searched it before buying it. There are a buncha threads on how shitty the 50/50 stuff is..
Actually, it's not terrible if you upgraded from vtec to vtech though, but I'd still stick to full synthetic
Old Jun 20, 2012
maxtierney's Avatar
EM2ti
Agree, I always replaced mine with the timing belt.
Old Jun 20, 2012
next belt change im also replacing the cam pulley because it was completely rusted last time i saw it.
Old Jun 21, 2012
Meh...
i noticed my grandma had v tech the other day, im like gram! what is this crap? i dont even have v tech....but she had someone come to her house and install it where as to me it sounds like a hard diy.... anyone done this care to input for my sake?
Old Jun 21, 2012
Aetoc's Avatar
Don't even bother trying unless you're a certified vtec installer...sh*t's hard man!
Old Jun 21, 2012
Kenny the Ricer
just make sure you set your vtech to 2.4ghz, or you wont get the best response
Old Jun 21, 2012
Meh...
tried the install before checking back with you guys :/ broke the cam stretcher clean in half, off to honda tomorrow to pic up a new one for 4k....hooray for spending money p.s. the t66 sucked soooooo much air!
Old Jun 21, 2012
Dude... Search next time.. T66 doesn't play well with the D17.. Install a Gallo 24 and all your worries will go away. It's the same price and works SOOOO much better under the hood..
Old Jun 21, 2012
I am Epic
you mean the auto tensioner?
what about AC and alternator pulleys or camshaft pulley? they dont ever need replacing?
Old Jun 22, 2012
Alt and ps pulleys are solid metal dude... I mean, if you wanna just spend money, by all means.. You can send that cash my way if you so desire, as well...
Old Jun 22, 2012
dude, where the hell did you get your gallo 24?!?!? i been looking for one for the past year without any luck....
Old Jun 22, 2012
Aetoc's Avatar
I didn't know pizza places made motors...
Old Jun 22, 2012
Quit searching for the Gallo 12 and you'll prolly find one no problem, you silly ****..
Old Jun 22, 2012
Meh...
thinking about a w16 convert in the 7th gen now, anyone shed some light?
Old Jun 22, 2012
Kenny the Ricer
W16 would never fit inside the hood, unless you carve into the firewall.
and it doesnt have vtak, so wiring would be a mess.
Old Jun 22, 2012
pjb3's Avatar
When an auto tensioner is replaced it is usually not because the pulley is worn but because the spring that supplies the tension is weakened. In the case of the timing belt it is done before the spring weakens and the timing belts slips.
There is nothing in the A/C, alternator or camshaft pulley to wear so no need to replace.
Old Jun 22, 2012
rjones7755's Avatar
The only w16 that will fit in the civics engine bay without cutting into the firewall is the 8.0l from the veyron. You just need a stage 2 clutch. Otherwise its a direct swap
