cant unplug o2
Old Mar 22, 2012
m3gach33zy's Avatar
Delightfully tacky. Yet unrefined
m3gach33zy is an unknown quantity at this point
cant unplug o2
I've been trying with all the might i have and I cant get the bitch to unplug am I missing some sort of like squeeze tab??
Old Mar 22, 2012
maxtierney's Avatar
EM2ti
Re: cant unplug o2
This might be a stupid question, but are we talking about the sensor on the exhaust pipe or the electrical connector?
Old Mar 22, 2012
m3gach33zy's Avatar
Re: cant unplug o2
electrical connector. Got it off from the header though. Now I cant figure out how to get the bottom bolt that connects the header to the car because its kinda blocked by the bottom 02 sensor. also i cant fit any kind of tool in there to unscrew the o2 sensor or get the bolt off from the bottom because its blocking it D:
Old Mar 22, 2012
lowlife9's Avatar
Re: cant unplug o2
they make tools for this specifically
http://www.amazon.com/b?ie=UTF8&node=15708831
Old Mar 22, 2012
m3gach33zy's Avatar
Re: cant unplug o2
Thanks. I went through about every wrench my dad had and I finally found one to fit. Had to torque it with a 5lb metal mallet but it came right off. Got the exhaust all installed too! Now I just have a rattling problem because I couldn't get one part back into the rubber donut
Old Mar 22, 2012
lowlife9's Avatar
Re: cant unplug o2
dam 02 sensors are pretty sensitive i hope you didn't damage it.
Old Mar 22, 2012
m3gach33zy's Avatar
Re: cant unplug o2
Doesnt look like it, but some of the bolt part is kinda stripped. On another note, I totally forgot to buy extension cables. Can the o2 sensors just lay around in the engine bay or should I wrap them up for the time being?
Old Mar 22, 2012
lowlife9's Avatar
Re: cant unplug o2
extensions ??? did you install a ex header and exhaust ??? you won't really know if its damaged till its all hooked up but i would at least zip tie the cables and tape up the connections so debris cant get in them
Old Mar 22, 2012
m3gach33zy's Avatar
Re: cant unplug o2
No, I installed a DC header with a DC downpipe. I've also found out that the header doesn't have a plug for an o2 sensor, but the downpipe does, which is why I need an extension. But what am I supposed to do with the o2 sensor that went to the header?
68camerors
Sep 24, 2015 06:18 PM
thaler4cuse
Sep 7, 2015 08:25 PM
