need help asap
Old Oct 14, 2011
civicboy05's Avatar
civicboy05 is an unknown quantity at this point
need help asap
so i just installed a 05 civic lx led cluster into my 05 dx, i did the pin out swap to a tee i only two wires i was missing were two blues one and i have a extra white/red wire. now everything lights up tach works fuel and temp works,but my speedo doesnt work at all i know theres probably somthing on here about this but i cant find it sooo can someone please help me
Old Oct 14, 2011
Re: need help asap
hate to tell you, but the speedo is prolly broken. the four gauges are all on the same drive circuit. so either none of them work or all of them work (along with the odometer display). so if everything but the speedo works, the cluster is bad. you can do the calibration test to know for sure.
Here ya go:
1. Push and hold the trip/reset button.
2. Turn the lighting switch ON.
3. Turn the ignition switch ON. (don't start)
4. Within 5 seconds, turn the light switch OFF, then ON, then Off again.
5. Within 5 seconds, release the trip/reset button, then push and release 4 times more.
Takes a try or 2 to get it. The odometer has to be in mileage mode, NOT trip mode when you do this. All the needles will sweep back and forth once. To exit, turn off the ignition. Just push the trip button again to see the needles sweep again while in test mode.
Old Oct 14, 2011
civicboy05's Avatar
Re: need help asap
Hey thanks man I'll try it today. But what is the extra white and red wire I have? Do I need the two blue wires that the other car had but mine doesn't ?Thanks again man
Old Oct 14, 2011
Re: need help asap
some stuff you may not have since yours is a dx (like abs, side srs, etc). i also noticed you are in canada so a few things may be different. i believe there is supposed to be an extra wire tho that is not used. if everything else is working like all the warning lights, you should be good. turn the car on and take a pic of the cluster to see that all the warning lights turn on. most will go off within 5 secs so the pic will help you see them all (except washer fluid and gas lights).
Old Oct 14, 2011
civicboy05's Avatar
Re: need help asap
Gearbox mad props bro. Turns out my green connector has a bad conection. Thanks for all the help bro.
Old Oct 15, 2011
maxtierney's Avatar
EM2ti
Re: need help asap
Nice! I wanna try the calibration test, just to watch the needles sweep back and forth. Learn something new everyday.
Old Oct 15, 2011
lowlife9's Avatar
Re: need help asap
i was thinking the same thing but with my luck it will probably break it.
Old Oct 15, 2011
Re: need help asap
i think if somethings wrong it says ERR in the odo window.
Old Oct 15, 2011
lowlife9's Avatar
Re: need help asap
so how do you enable the launch control ???
