Got an issue here need a little advice.
A scene before your eyes
Been noticing a little concerning issue lately. I pulled my ignition coils out to change the plugs and I have noticed that plug two and four have what appears to be an excessive amount of carbon build up all over there shats. The plugs are not terribly dirty but they are slightly carbon covered. research has shown here in the forum that the fuel air mixture is causing the carbon build up as not all of the fuel is being consumed in the combustion process. However it troubles me that only two coils and plugs are suffering this issue and not all four. Upon closer inspection the coils in question have a significant burnt smell to them and are slightly darker in color than the other two. What could be causing this and what can or should I do to fix it?
Rep Power: 788 Re: Got an issue here need a little advice.
maybe small oil seepage from the tube seals? its normal for them to look old. if theres liquid, its prolly a leak. if the car runs fine, i wouldnt care.
Ok, oil seepage huh. Alright, the car runs good but I was just a little worried that it may lead to a larger more aggressive issue in the future. I had a Mitsubishi some time ago and I pressure washed the engine, anyhow, it led to a smoldered plug but the engine started just fine and I drove that bitch down the road on three cylinders. The smell of burnt eggs was horrible. Im not getting a smell now and there is no power loss but I thought I should be a little worried.
Thanks
Thanks
Harding12390
04-06-2018 11:43 AM
danace99
23
06-28-2015 08:49 AM
crowtoo
05-11-2015 06:50 PM
pincookie1
05-04-2015 12:22 PM
PiCASSO
04-06-2002 12:18 AM
