Cylinder Head Plug Leak
Old Jul 25, 2011
ltrunfio's Avatar
ltrunfio is an unknown quantity at this point
I have '01 Civic EX with an oil leak. I sprayed it down with engine degreaser and traced source to the cylinder head plug (other posts have called it the cam seal but the diagram of the engine shows part number 12513-P72-003).
I've found a few other posts with the same issue but am trying to assess if it's something I can do myself. I've taken the valve cover off, cleaned and re-sealed it, but talk of resetting the valve lash (don't even know what that is), removing rocker, and needing a torque wrench have me wondering if I'm out of my league.
Any advice would be appreciated.
Thanks.
Old Jul 26, 2011
maxtierney's Avatar
EM2ti
Re: Cylinder Head Plug Leak
Get a new plug from the dealer for 5 bucks. Pry the old one off with a screwdriver or twist in a self tapping screw and pop it off. Apply some Hondabond or black silicone on the plug. Pop it in. You don't have to pull the valve cover. Just clean the hole out before you put the new plug in.
Old Jul 26, 2011
inifiniteblur's Avatar
inifiniteblur is an unknown quantity at this point
wouldn't you have to drain your oil first? i had this done at the dealer. along w/ the oil pan gasket and some other gasket that they said i needed. (part # 12030-PLC-010)
$461 later and the cylinder head plug started leaking again after about a week. now im going to just put that silicone or something else on it.
Old Jul 26, 2011
maxtierney's Avatar
EM2ti
Nope. Takes 10 minutes. No oil drain, nada. You can reuse the old one, just reseal it well.
Old Jul 26, 2011
just dont drive for 24 hrs lol. you dont want hondabond being part of your internals
thana
Jun 15, 2020 07:05 PM
danace99
23
Jun 28, 2015 08:49 AM
Jun 2, 2015 11:54 AM
zaboomafoozarg
May 30, 2015 09:21 AM
bsmiley
Apr 27, 2015 01:27 PM
