Urgent help required please help!
Hi there i just removed the rubbish front door speakers in order to fit my new Alpine SPR-17s in. After one hour trying to figure out how to pop out the door panel and hammering out the speaker i found that i can actually fit the alpines in the existing spacer but the panel won't pop back on. Has anyone else had this problem if so can you tell me what sized spacer i would need in order to pop them in and the door panel back on top??
urgent help required!!!!
thanks for looking
thanks for looking
Re: Urgent help required please help!
if the door panel wont go back, just cut the excess plastic lip on the back of the panel around where the speaker is. its useless and easy to cut off with a knife. if the window is hitting the speaker when you roll it down, then you need a thicker spacer.
I thought I am the only person who cut those plastic lips out. I believe when I mounted the speakers I did not align the speaker at the same height because I tried to cover the small hole above the big one.
Touge
Sep 23, 2015 10:51 PM
Bruce2
Sep 21, 2015 08:01 PM
