TYC's and Morimoto Mini's
Old Jan 30, 2011
DarkSouljur's Avatar
DarkSouljur has a spectacular aura aboutDarkSouljur has a spectacular aura about
So i've read a couple threads and after realizing that the morimoto mini's were a lot cheaper than i expected, that instead of putting HID's in a halo projector housing that i would just stick to OEM blacked out headlights with morimoto retrofit since it wouldn't require any modification.
But i would rather retrofit a TYC headlight so i was wondering if any modification was required for TYC's with morimoto mini's. If there is then i'll probably save myself the time and money and use it else where.
Old Jan 30, 2011
Re: TYC's and Morimoto Mini's
i dont know anyone who has done it. the tyc adjusters might line up, but it would still be a pain to aim them. in stock housing, aiming is easy with the stock adjustments. the easiest way is morimoto in oem housing if you want least amount of work and no custom stuff.
Old Jan 31, 2011
Alright i guess i'll just do it in stock housing, also do you know what size CCFL halo ring i'd need? And is there a DIY for the halo rings because i don't know how to put them in
Old Jan 31, 2011
i wouldnt bother, they are not reliable and you will have to open everything just to throw it out when it fails.
Old Jan 31, 2011
Aw damn, i've always wanted halo's. You win some you lose some, thanks
Old Jan 31, 2011
My CCFL angel eyes are mounted with 3m double sided tape.. lol
Old Jan 31, 2011
Are they working fine? And how long have you had them assuming they haven't burnt out :P
Old Jan 31, 2011
how long have I had them.. lol.. They sat around for years because my work schedule didn't really permit me ripping my headlights open.. I think I got around to putting 'em in.. last year april-ish? And they're working fine still to this day. In my sig, click the "her lights" link. Scroll down to post 5, and you can see 'em lit up in pics 3 and 4
Old Feb 1, 2011
Wow lol, at least they still worked when you put them in! They do look pretty nice, and you just used 3m tape to put them in? I'm getting it wasn't too hard to connect
Old Feb 4, 2011
mc670's Avatar
mc670 is an unknown quantity at this point
does it matter what kinda of hid ballest you use?..and would you need a relay harness? Im thinking about doing this to the stock lights on my '05.
Old Feb 4, 2011
yeah ballast has to match the bulb you use. so if you go with d2s, you need d2s ballast. if you go with the h1, you can use most aftermarket ballast with amp connector. and you need a new relay harness, stock wires are too thin to support hid.
Old Feb 5, 2011
sl33pyriceboi's Avatar
morimito > tyc
anyday.
Old Feb 5, 2011
mc670's Avatar
Im a bit of a noob when it comes to this hid stuff.. whats a d2s? a diffrent type of bulb. I'll be going with H1 bulbs.. probably 6000k if i decide to do this. In theory i guess i'd need this..
http://cgi.ebay.ca/XENON-LIGHT-HID-C...item4151f418ae
and this?
http://cgi.ebay.ca/HID-Fuse-Relay-Ha...item3cb4306243
Sorry if im wrong and highjacking the thread.. if i am wrong can someone point me in the right direction?
Old Feb 5, 2011
yeah d2s is oem bulb size. if you use h1, pretty much any aftermarket ballast with amp connectors will work for it.
Old Feb 5, 2011
Do you need a relay harness if it's 35 watt?
Old Feb 5, 2011
yes. the problem is not stable running, its the initial high amp draw for the first few seconds that can fry the stock thin wiring.
Old Feb 6, 2011
Can i just pick all these up on ebay or is there a better place? I'm going to be spending like $200 for retrofit i didn't want to spend too much more on headlights xD
Old Feb 7, 2011
A retrofit is the way to go.. I ran with the ghettofied PnP kit in halogen projectors for a while.. The light output in a retro is SOOO much better, and I'm even rocking a "shitty" HID retro.. by shitty, I mean an HID projector with a lower light output than others
Old Feb 7, 2011
you should try the osram CBI bulbs people are talking about on hidplanet. 5000K and same brightness as other oem bulb. most users report its even brighter and much whiter. seems to fare well in most projectors (esp the japanese ones like TL, tsx, s2k, etc).
Old Feb 8, 2011
5000k is pure white isn't it? I need a hint of blue do they come in 6000k?
Old Feb 8, 2011
philips ultinon 5800k then
Dave Brabant
Sep 27, 2015 09:43 PM
h4ldol
Sep 17, 2015 01:25 PM
