Can I do this?
Old Aug 12, 2010
02CivicKing's Avatar
02CivicKing is an unknown quantity at this point
Question Can I do this?
http://www.carid.com/2002-honda-civi...tor-83687.html
Can I put H.I.D kit with these aftermarkets?
Old Aug 12, 2010
Re: Can I do this?
Short answer: Yes.
Long answer: You're gonna need to do some modification to the projector itself to get the HID bulb to fit (i.e. take a dremel to the back of the projector where the bulb fits into, and making it bigger to accommodate the HID bulb.). The light output will be, well, decent, I guess, but one this I regret doing is fiddling around with HID kits in halogen projectors. With as much time, money, and effort as I've spent messing with the HID in halogen projector setup, I could have done my own retro. The light output of my retrofit is vastly better than my H1 HID kit ever was.
Old Aug 12, 2010
sam68's Avatar
sam68 is an unknown quantity at this point
Re: Can I do this?
I agree after reading a lot I went with a retro kit mini mottos from the retrofit source in some stock type housings. The cost was a bit under $400 with the new housings and they told me it is easy to retro fit them in the stock type housings, more room less problems aiming them correctly, so I will be setting them up this weekend in the housings.
Old Aug 15, 2010
Re: Can I do this?
Did you happen to look at the lights I want listed above? I went to that site you listed above and emailed them about what size I need to get. Can you post some pics of your set up and maybe the procedure you went through? Parts used or suggested as I suppose your parts will be somewhat different from what I need to order for my headlights.
