Air flow sensor
Air flow sensor
I took my car to the dealership today (04' civic lx sedan). they said my air flow sensor is messed up and they want to charge me 340 dollars to fix it, 98 dollars is for labor... I think that's a little ridiculous. What do you guys think. How many air sensors are there? I found a MAP Sensor for like 62 bucks and i can't imagine it being too terribly hard to replace. Thanks
Re: Air flow sensor
um yeah the only air sensor worth mentioning is the MAP sensor which is for air pressure. pretty cheap, even the oem part is less than $100 and it takes a couple mins to change.its next to the throttle body and says map sensor on it. i think its denso brand. there is also an air temp sensor in the air intake housing and thats maybe only $10 and can be changed in couple secs.
Re: Air flow sensor
don't the dx and lx's have the cat right next to the block, and don't they have the laf sensor (linear air flow sensor) looks like an 02 sensor but has 5 wires. I know this because i had a vx civic that had one, the part is hella expensive cause i think there is very few aftermarket replacements
Re: Air flow sensor
honda still calls this an oxygen sensor i believe on 01+ civic
tmc66
Jun 9, 2015 04:07 PM
juror
May 26, 2015 06:35 PM
mievil
Apr 28, 2015 11:02 PM
