Engine Management on the low.
Ok, first off, this has potential to be alot of work, maybe too much. But has anyone heard of or used a megsquirt Engine management system? http://www.diyautotune.com/
It is a cheap as hell engine management system that seems to be just as good as anything else. My thought was to use this, and totally rid a civic of the factory ECU. Then with adjustable tunings, shouldn't we see more HP from regular mods? Theorhetically, couldn't we adjust Air/Fuel and stuff, so that the car is making much more power under acceleration and getting much better gas mileage for cruising? I was looking into this, but my car doesn't have much in the game of performance (short air intake and muffler), si I doubt that I would see much of an improvement. But, it seems to have potential. Looking for any and all comments.
Re: Engine Management on the low.
Your talking about using a MegaSquirt right? I was thinking about using one. However I heard somebody say that it might not work with coil on plug ignition. I don't know if thats true or if the current version supports it.
I would have to check into that some more. They are supposed to have excellent forums to help you (if you've done ur homework and know what the hell ur doin).
On to the coil on plug....I may be wrong on this....but I wouldn't call this a coil on plug system. I would say it was individual coil for each plug, but would call the setup on Ford modular engines (4.6, 5.4, and V-10) more of a coil on plug system. Either way, you may be right, but I would think that as long as something tells the coild to fire, they will fire.
In a random direction, if that were a problem, couldn't a fix be to set up a MSD box or something and running regular plug wires to the plugs?
If my income could keep up with my engineering mind, I'd be turning out awesome stuff all the time.
It very well could be a nightmare. Having to solder different jumpers on a board. Basically making a new wiring harness. I happen to be very good at wiring and like to do it so not a big deal to me. They also sell the boxes preassembled. All our engine needs to run is air fuel and spark. This could provide all of that. There is no question in my mind as to whether it will work, but more of a question of how good, and how hard to incorporate this. I yearn for the old days when people slapped on some headers, turned a screw, adjusted their timing and made god-aweful horse-power. I believe fuel injection has potential to be better than a carb at every possible thing. The only problem is that the car companies don't make them adjustable.
Does anybody know of a computer program that could adjust our factory ECU's?
mikemc422
Aug 9, 2018 05:41 PM
Flipg123
May 8, 2015 01:15 PM
F1wanabe
Apr 27, 2015 11:06 PM
