removing my 5 speed transmission
Old Nov 22, 2009
05simplecivic's Avatar
05simplecivic is an unknown quantity at this point
transmission broke last night, need to replace it, just have a few questions.
I've never messed with a manual transmission before, so my concerns are related to the clutch. Is there anything i need to lookout for when i take the trans off/install? Ive read about a clutch alignment tool not too sure what the deal is when installing the trans back to the engine.
Im going to attempt to remove the tranny from underneath the car like this guy.
https://www.civicforums.com/forums/1...n-removal.html
Or do you guys recommend i remove the whole engine/tranny all together? for an easier install.
Oz
Old Nov 22, 2009
greeen01civic4d's Avatar
Re: removing my 5 speed transmission
u dont have to worry about clutch unless ur replacing it. drop out and reinstall, ull be fine
Old Nov 22, 2009
Cool, thanks for the info... I patched up the tranny with JB WELD, hopefully that was the problem (low oil) if not im going to hit this thing hard and quick.
Old Nov 24, 2009
WannaBFast's Avatar
Prowlin' with a Purpose
yea taking it out the bottom requires you to remove the subframe, which is like 6 bolts and you need to drop the lower control arms too, that way you dont need to mess with the sway bar links
ive gotten my transmission out in an hour before.. with power tools that is
GolNat
Suspension DIY
May 12, 2022 06:49 AM
ImmortalEX
Detailing
78
Sep 4, 2015 05:35 PM
97-DX-Lover
Jun 14, 2015 06:07 PM
bsmiley
Apr 27, 2015 01:27 PM
2k2civic
22
Jan 19, 2002 06:21 PM
