What is this..?
Old Sep 13, 2009
tinnguyen123's Avatar
tinnguyen123 is an unknown quantity at this point
What is this..?
What is that Gray thing underneath our car..? it look like something you can put into a computer.. look like a connector into some other part..
im not sure.. but it might be call OBD.. i have NO idea what it is.. can someone enlighten me..?
I wish i can take a picture to show you guys but it RIGHT under our fuse box but the wire comes out from the center of where our radio is located.. there is even some metal thing to rest it there.. seem reallly important..
Old Sep 13, 2009
lowlife9's Avatar
Re: What is this..?
i think you answered your own question.
Old Sep 13, 2009
seoul4korea's Avatar
seoul4korea can only hope to improve
Re: What is this..?
OBD-Level 2. On board diagnostics. it has to do with your EMS. That is that port that you can access your computer from for things like Checking trouble codes and EMS reflashes.
Old Sep 14, 2009
GreenMachineDX's Avatar
GreenMachineDX is an unknown quantity at this point
Re: What is this..?
Lol...
Old Sep 20, 2009
Re: What is this..?
sad.. >.< well i took my car to the mechanic and saw them use those OBD reader thing on my car.. and i happen to have 4 stupid mother F!@#ing error.. has ANYONE.. have this.. all i did was pull the ignition coil fuse out.. and boom flipping light was on..
Old Sep 20, 2009
lowlife9's Avatar
Re: What is this..?
what were the codes ???
Old Sep 20, 2009
baron340's Avatar
baron340 is a glorious beacon of lightbaron340 is a glorious beacon of lightbaron340 is a glorious beacon of lightbaron340 is a glorious beacon of lightbaron340 is a glorious beacon of light
Re: What is this..?
Yeah.. I think my record is like 9 at one time. That was fun.. anyway. What were the codes? If it was misfire codes that is not uncommon. You often get a random misfire code, and a misfire code for each cylinder.
Old Sep 20, 2009
Re: What is this..?
they prolly didnt tell him the codes, they wanted to "fix" his car and make $$. its prolly all useless codes that wont come back if you reset the computer.
Old Sep 21, 2009
Re: What is this..?
Let me guess your ECU was dying???
Ok. It's seems by this post in the first place that you need alot more help then your telling us. As stated from the other people We need your codes because we can look them up or you can even look them up on the internet.
http://www.obd-codes.com/trouble_codes/honda/
now you said your ignition coil before that is an easy fix. Just order one from auto zone for like $23. Its like 2 wires + the cable going to the distributor.
Do you live in California?? if not then go to Autozone and ask them to run your codes for you OR spend some money and buy a OBD-II scanner and pull the codes yourself. Any guy that is charging you to run your codes and won't give them to you is worthless. Let us know what you get so we can try and point you to the right direction.
jdm_bb
Mar 11, 2004 10:29 AM
HCCriminal
Apr 4, 2003 08:37 PM
