strange noise.
strange noise.
when i come to a stop i hear a rattling hissing noise that slowly dissapates after a complete stop could my exhaust be the problem the noise is from under the car.
Re: strange noise.
rattling hissing? what kind of exhaust are you running? and is it a full catback?
the only rattle thats 'normal' is the one where the flanges of two pipes connect right below a heatshield under the passenger side. and even that rattle should only come when its snowing or raining out and the water gets in there.
Re: strange noise.
i have fuul header back 2.5 tsudo N1 ok it was raining when it started to rattle but i modified the heat shield so the flange won't hit it. today i drove it and it didn't rattle but it still makes the hissing sound when i installed the system it did have a miner leak im guessing it got worse with time also i didn't use the spring bolts because they were rusted badly . maybe i should cut the flanges and weld everything together.
Re: strange noise.
today i got under the car and tightened everything up the down pipe was really loose at the donut gasket it seemd to do the trick but im going to ordr a OBX twin loop to replace the N1 im tired of it so im going to cit the flanges and weld it together also to gain some clearance.
jdawgzcivic
17
Feb 1, 2020 04:16 PM
i drive
Sep 14, 2015 01:56 PM
