D17 Cam Gear tuning
Old Aug 4, 2009
Michalo187's Avatar
Abortion Survivor
D17 Cam Gear tuning
Hi guys, I am trying to get a little more power and get my car to run smoother and I have been tuning it with Aem Ems and lately I have been wondering if I should mess around with the adjustable cam gear....I searched old threads and I found one where gearbox claims he made more power retarding his car 1.5 degress. The reason I am nervous is because i have the crower stage 3 cam and many people say the valves can hit the piston easier. Any suggestions or past experiences would be appreciated. I have tried retarded it 1 degree already and it feels a little better all around actually.
Old Aug 4, 2009
baron340's Avatar
baron340 is a glorious beacon of lightbaron340 is a glorious beacon of lightbaron340 is a glorious beacon of lightbaron340 is a glorious beacon of lightbaron340 is a glorious beacon of light
Re: D17 Cam Gear tuning
You should be able to get it to run smoothly without adjusting the timing mechanically. That stage 3 cam will only idle so smoothly though, it's a big lobe cam, it will only get so quiet before you can't go any further.
Old Aug 4, 2009
Michalo187's Avatar
Abortion Survivor
yeah i know and understand that because of the big valve lift it will always have to idle higher and have funking sounding idle to some people but I am wondering if i can get more power outta of adjusting it and if the power is worth the risk if there are any risks.
Old Aug 4, 2009
baron340's Avatar
You might be able to get a little, but it isn't going to be much, and you are going to have to put it on a dyno and make pulls to figure it out.
Old Aug 4, 2009
Michalo187's Avatar
Abortion Survivor
you think 2 degrees either advance or retard is as much as i wanna go?
Old Aug 4, 2009
baron340's Avatar
If you are boosted, I honestly wouldn't even worry about it, just run the standard timing retard for your boost level. If not, you can play with it some, but timing can kill a motor quick if you dont' do it correctly. I'm talking melted spark plugs or pistons, nasty detonation, the list goes on.
7thgensurvivor
Aug 26, 2015 06:17 PM
WaryDriver
Aug 16, 2015 11:22 AM
Masaru
Aug 10, 2015 06:20 AM
f575gtc
Transmission
Jul 13, 2015 09:16 PM
Ccoop87
Jul 9, 2015 03:26 PM
