More Wide Band Help!
Official Rattlesnake Hunter
original thread.
https://www.civicforums.com/forums/7...band-help.html
i bought this.
http://shop.edoperformance.com/plx-a...or-p-9152.html
first of all the product i bought was used, second it didnt come with a ****ing A/F gauge...
The A/F gauge cost another $75 for a grand total of $275 plus shipping...($300) Now im like **** it, ill just get the UEGO.
Question in all the UEGO pics the isnt a "sensor modual" like the PLX came with...
http://cgi.ebay.com/ebaymotors/AEM-U...spagenameZWDVW
do i need the "modual sensor" that cam with the PLX?
Why doesnt the UEGO come with a "sensor modual"?
ill be running AEM FIC on my 7th gen...
i bought this.
Re: More Wide Band Help!
No you do not need the module for the UEGO....that is only for the PLX system....it's like a little computer to store your data......UEGO has actual wires you can run into your AEM computer for datalog and what not. PLX module only goes with plx setup...UEGO has a blue & white wire for output
AEM wideband doesn't use a module. The module is built into the display. The reason plx uses modules is for transferrance of data and because the iMFD system is a usb controlled display which is too small to convert data, that's what the sensor module is for.
You should be able to datalog the fic with the uego. Just a sensor and gauge.
its has taken me over two years to buy all that i have... (which isn’t much)
if i could afford Kpro i would...
it would just be 2012.
Thanks for the help.
from my understanding using wideband you run into this:
A. Buy a A/F guage (which is actually narrowband) unless you buy a wieband kit (additional), for this youll need to weld in a bung onto the exhaust maifold and this is where the additional o2 sensor will go in conjunction with your A/F guage.
B. Buy a widband A/F guage, this kit comes with all the stuff needed but will usually run for 350.00+
in your concept....
it does not state that it comes with the LED GUAGE
EX:
SM-AFR main unit
Bosch LSU 4.2 wideband sensor
O2 sensor harness 10ft
4ft power wire with 2.1mm connector
4ft Analog wires and connector with 4 terminals
1ft Serial Cable
Termination jumper
Quick start guide
i think you need both the A/F guage and this to work for what you need?
correct me if im wrong but im sure this is how it goes?
in your concept....
EX:
SM-AFR main unit
1ft Serial Cable
Termination jumper
Quick start guide
Just to clarify what comes with an AEM UEGO gauge (30-4100)
You get the display gauge (which includes the controller built in).
You get the wiring for power/ground etc...
You get the UEGO sensor and harness.
And manuals etc...
The AEM UEGO is not a datalogger. It is a display. If you want to datalog it also comes with a 0-5V output in addition to the display and you connect that to your EMS, F/IC or whatever and datalog your AFR just like you would any other sensor.
And manuals etc...
Supramk3
Jun 11, 2015 11:13 AM
