energy motor mounts??
Old Jan 29, 2008
eggot's Avatar
eggot is an unknown quantity at this point
anyone here know of a DIY on these motor mounts. im new to this site and have been looking around for this diy everywhere but i cant find on. please let me know. its for a 2005 civic ex. thanks again
Old Jan 29, 2008
hypnotic20's Avatar
hypnotic20 is an unknown quantity at this point
Re: energy motor mounts??
Oh man, I plan on doing the same thing... I guess I'll write a DIY when I have the time.
Old Jan 29, 2008
eggot's Avatar
haha alright let me know alright. thanks..
Old Feb 12, 2008
eggot's Avatar
did you do this yet??? please let me know. or anyone else do this
Old Feb 12, 2008
speedfoos's Avatar
No need to write a DIY on it, it's a pretty easy mod.
Remove front mount, install ES bushing inserts (There are like 3 bolts), re-install mount.
Unbolt rear mount - paying careful attention to how you have to turn the mount to get it out. I didn't and spent the better part of an hour trying to get the damn thing back in there in the correct position. I also suck at Rubic's cubes and puzzles.
The thing with the rear mount inserts is that you may have to trim some of the poly off to get them to fit properly. I know I did. Just use a box cutter with a new blade and you'll be fun. It's a really easy mod though, which is why there is no DIY.
Old Feb 12, 2008
greeen01civic4d's Avatar
umm, i think i did a diy on this, hold on
Old Feb 12, 2008
ok, here is the diy, btw, all i had to search for is esmm diy...
https://www.civicforums.com/forums/7...ll-help-2.html
Old Feb 12, 2008
speedfoos's Avatar
LOL - forgot all about that thread. Good stuff Adam. Let me see if I can rep you again.
Old Feb 12, 2008
thanks Clint!!
Old Feb 12, 2008
eggot's Avatar
thanks very much guys. i ran out of time so ill do the rear mounts some other time. but when i installed the front mounts. i didnt really notice the difference. do you have to have both of them installed to feel the difference??
Old Feb 12, 2008
no, the rear just further stiffens, it may give u some vibration, did the diy help u?
Old Feb 12, 2008
eggot's Avatar
so it would be better if i installed the rear ones?? just in your opinion lol??? but yes the diy did help but i have a 2005 and i had an extra bolt. i was trying to wiggle it a little and no budge. so i looked underneath and there was another bolt. but other then that yes it was a very helpful diy for the front ones. havent tried the rear ones.
Old Feb 12, 2008
the rear will help, but u may get some vibration when putting a load on the engine, but trust me, ull love it, i do
Old Feb 13, 2008
bomerman19's Avatar
bomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond repute
IMO the front one is the most important because the front stock mount on the 7thgen's has a tendency to rip apart. Most stealerships tend to have a couple on stock at all times since they break so much. but with the es front mount in it stops the rubber from ripping in the stock mounts.
The rear mount is a pain to put in though. do what foos said grab a blade and shave it down.
Some one should probably send ES a note telling them that they need to recast there rear mounts
Old Feb 15, 2008
eggot's Avatar
i cant get to the rear ones. the cat gets in the way of one of the first 2 bolts.. the ones that you say need to be breaker bared.... so yeah and for the other 3 bolts. mine goes the other way. your third bolt goes left mine goes right and i cant even get in there to do it. so i might not even try. so i think i might just stick with the front ones..
Old Feb 15, 2008
bomerman19's Avatar
Just unhook the front rubber hanger for the cat you should then be able to push it enough out of the way to get to the bolt if you still can't get it. Get a 12mm socket with an extension and take off the two spring bolts that hold the header to the cat then you can move the cat like 3 feet to the side lol
mistermenphis22
Jul 13, 2015 04:43 PM
manfredww1
Jul 12, 2015 07:31 PM
671civicLX
Jul 9, 2015 03:22 PM
