question about defroster
Rep Power: 0 question about defroster
According to the manual for the 2006 Civic, pressing the windshield defroster button overrides all previous settings and should turn on the A/C. However, I don't find this to be the case. I'm pretty sure it used to be true, but I just had the audio system or stereo trim repaired because the backlighting wouldn't work, and apparently controls were transferred.
A/C works (the button light turns on) when I press the button.
Should pressing the windshield defroster button always cause the A/C to turn on if it was previously off?
Rep Power: 0 Re: question about defroster
I'm still not sure about proper behavior: if I depress the windshield defroster button, should the A/C light come on under all circumstances? (I understand that it can be turned off). When I depress the windshield defroster button, the A/C light never turns on automatically.
Rep Power: 787 Re: question about defroster
you are talking about the actual rear defrost button for the window heater lines and not the front window defrost air vent setting right? in which case, a/c should never come on. the defrost system does use a ton of power tho. at first i thought the a/c came on silently (without the light coming on), but i couldnt actually hear the compressor. when in doubt, open the hood and see if you hear the compressor click on. i really do not see why it would need to turn on tho, since rear defrost has nothing to do with the a/c system. now if youre talking about the dial setting for front window vent defrost, then yes the a/c light should always come on, and there is a special code you can do to have control over it so you can turn it off. also remember, just because the a/c light comes on, does not mean the compresor is working. it has a pressure switch lockout and usually will prevent compressor function below freezing temps.
More importantly, what could be causing this problem? As I wrote, if I press the A/C button manually, it will light.
no, the special code allows you to turn off the a/c once it turns on. it should still come on all the time by default. without the code, there is no way to turn it off once it comes on. a few guys here with 8thgens said the same thing and they did the code so they could switch off the a/c after switching to defrost mode. i have no idea why its happening, but really is it a big deal? i mean, if you push the a/c button and it works, then i wouldnt worry. i would actually prefer it to be like your setup, so i dont have the a/c compressor running for 2 seconds before i switch it off again.
Doesn't one want the a/c to turn on automatically most of the time?
BigG422
09-09-2015 10:59 PM
jpandjf
08-03-2015 05:02 PM
