8th Gen 2006 - 2011.
overdue oil change
Old Dec 15, 2018
  #31
rogerscivic's Avatar
rogerscivic is an unknown quantity at this point
Re: overdue oil change
Originally Posted by ezone
The puncture (or repair) may have damaged a steel belt.
You got 78% Nitrogen.
Oh ..ok" it was a small size screw guess thats all it takes to damage a steel belt. i got the front wheels on the back now so for now i have no shimmy shake wheel shake. thank-you for all that posted.
Old Dec 15, 2018
  #32
brags's Avatar
"Honda - tried, true & tested...!"
brags is an unknown quantity at this point
Originally Posted by rogerscivic
my friendly neighbour next door streteched out his air line gave me air no nitrogen just regular air.
If You got Your Air from One of those big size compressores like shops use.? You could of gotten water in the tire if the compressor used was never drained of water. You might have it in Your tire. thinking Back i have heard of this happening to someone that got some water in there tire along with air "caused all sorts of steering wheell shakes and
vibrations". the big sized compressores need to be drained of water time to time or it builds up under the belly of the compressore thats why there is a water drain found below it. Im Just putting this out there its something i remember hearing about as a posibility.
Old Dec 15, 2018
  #33
"brags i think Your onto something Here", i have not heard my next door neighbour start his compressor in a long,long time. im guessing he also has not done anything to it either. he use to use it all the time since he restored old furniture. i would here it on almost every day, since he stoped though never heard it run anymore, until the day he seen me. he
offered to put air in my tire i almost think your dead on about having water in my tire from his compressore it is a big industrial kind and by coincidence my trouble with the shaky wheel only started after getting air from his compressore".. i will ask him next time i see him thank-You ! once more.
Old Dec 15, 2018
  #34
Some of the reamers used prior to inserting the plug are much bigger than the nail that made the puncture. Yea it can happen, but is it likely?
Oooh good call!
Whomever did the tire balance would have to be pretty damn observant to see it on the spin balancer though. IMO not many would notice.
Old Dec 15, 2018
  #35
Colin42's Avatar
Probably easier to tell if you take the tire off the car and shake it/move it around to hear the water sloshing
Old Dec 16, 2018
  #36
Oooh good call!
You would think so." after reading up on how water can get into a tire i realy beleive thats what i have, im going to pull off tire and shake it around listen for water sloshing thanks - again
Old Dec 16, 2018
  #37
I doubt you'll be able to hear liquid in the tire.
1 or 2 ounces is quite enough to cause imbalance, and the only way I know to get it out is to break down the tire from the wheel.
Old Dec 16, 2018
  #38
just finished taking my rear wheel off the back thanks colin42 and after shaking it. i could hear water sloshing around inside it. i would of never of guessed it if "brags didnt tell me about it ". i will be taking it to my mechanic next week and showing him what i found. thanks a ton brags.!! and the rest of members for this i truly appreciate the help on this hard to find problem that probably no one would ever of found on my Civic maybe we all here can meet up some time. for a tims coffee somewhere?
Old Dec 16, 2018
  #39
brags's Avatar
Glad to hear You found the problem i talk to many Professional technitions in the Automotive feild that have many Years of experience and Knowledge behind there lives, & experiences. many times they also have online web sites with podcasts on them that i Listen in time to time i heard of this same thing hapening to someone
before thats why to me it sounded like water in Your tire. especially after You mentioned getting Air from your neighbours compressor glad to be of Help.! Just sharing the Love Bud.
Old Dec 16, 2018
  #40
Colin42's Avatar
Glad you found the problem
crypticlineage
Dec 30, 2012 02:20 PM
stuartb1111
Feb 8, 2012 10:36 PM
ChrisC
25
Jul 20, 2010 09:31 PM
multio8618
Mar 25, 2009 11:43 AM
runner1738
29
Apr 18, 2005 11:07 AM
