8th Gen 2006 - 2011.
To stroke or not to stroke? (K24a2)
Old Aug 4, 2017
azbritton's Avatar
azbritton is an unknown quantity at this point
Cool To stroke or not to stroke? (K24a2)
2008 Honda Civic Si K20Z3
So right now I have a bored out fully built head with drag cartel 2.2 cams tuned on hondata Flash bro. (K20Z3) Full bolt ons. Runs on e85.
Next I want to swap the bottom end with a k24a2. Which as we know is a 2.4L. I'm going to replace the pistons and rods anyways so I was thinking of going with Brian crowers 2.6L or 2.7L w.e it is stroke kit with new crank. I also want to Turbo the car down the road.
So I guess my questions are:
1. Should I stroke it out with bc and new crank?
2. Should I just stay at 2.4 with new rods and piston? Stock crank.
3. What compression should I run if I plan on doing turbo down the road like a year after this swap?(What conperrsion would I want so I wouldn't have to change it if I went turbo or Not? 10:1.?)
I obviously know that staying at 2.4 with new rods and pistons and stock crank would be cheaper. But I'm ok with the $3,000 on the stroke kit if it is truly worth it.
Thanks for your "opinions" in advance!
