8th Gen 2006 - 2011.
2008 Civic LX ECM
Old 02-04-2016
BALISTIK BADGER's Avatar
BALISTIK BADGER is an unknown quantity at this point
Exclamation 2008 Civic LX ECM
I have a particular problem with my civic, it is experiencing battery drain issues in which I have been told could be the ECM. I have replaced the alternator and have had the battery check and all were fine. I was instructed to pull fuse 23?? which would lead to tell me if it is the ECm or not.
the real question is I was told I would need to take my car in to the local Honda dealership if I swap computer. any reason why??
thanks!
BALISTIK BADGER is offline
Old 02-04-2016
Re: 2008 Civic LX ECM
Rule #1: It's never the ECM. (PCM if it's got an automatic trans, and it's not the problem either.)
It's not real tough to figure this out through pointed testing if you know what you are doing.
Prove there really is an excessive drain by using an ammeter.
Then diagnose where that drain is.
I see bad batteries pass the digital tester tests almost daily.
Why? What would that do or prove?
For programming the immobilizer. The engine will not run until this is done.
That's an awful lot of expense for a (more than likely wrong IMO) guess.
ezone is offline
Old 02-04-2016
ok, I have heard that this year had issues with the PCM and the battery not charging from the alternator. I already replaced it and still having issues
Old 02-04-2016
Do you have an excessive drain on the battery overnight?
Or do you have a charging system problem?
Both systems can be tested to prove if there is a problem or not.
(I don't mean tested at Autozone.)
I personally have not witnessed a PCM cause either issue. Not saying it can't happen, but I have not seen it myself.
I've fixed various other causes of batteries going dead in those cars though.
ezone is offline
