8th Gen 2006 - 2011.
Squeaking/Creaking over bumps?
Old Jan 28, 2014
jordan1794's Avatar
jordan1794 is just really nicejordan1794 is just really nicejordan1794 is just really nicejordan1794 is just really nicejordan1794 is just really nice
2006 Honda Civic Lx Sedan.
Recently I've noticed a creaking/squeaking when I go over bumps. It's been steadily getting louder over the last few months. It SOUNDS like an older car that has gone forever since a lubrication, but as far as I know my car doesn't have lubrication points.
Any idea's what it could be?
I've noticed it when it started getting cold, don't see how but, could temperature be causing it? it hasn't gotten warm enough for me to see if it improves yet.
Old Jan 28, 2014
GolNat's Avatar
Prelude Owner
Re: Squeaking/Creaking over bumps?
The cold weather can affect a lot of things. Metals, plastics and fluids all act differently in cold weather then in hot, so it is possible that the cold weather is creating a problem or at least displaying a weakness.
Possibly your springs making noise against the mounts but not sure if they are suppose to lubed or not.
Old Jan 28, 2014
Sure. Damn near anything.
Start over, with some basics: Noise from where on the car?
Inside?
Outside?
Front?
Rear?
Drivers side?
Dash?
Dead hooker in the trunk?
Old Jan 28, 2014
jordan1794's Avatar
Front.
It really seems like it only happens on bumps, a sweeping turn for example doesn't really make any noise.
It sounds to me like the suspension making noise when it compresses, but I don't know very much about suspension.
Old Jan 28, 2014
jordan1794's Avatar
And its from both sides, driver and passenger.
Old Jan 28, 2014
If you go bounce the front of the car (by hand or with a knee), will it make the noise?
Narrow it down further. EDIT: Scratch that last line.
Old Jan 28, 2014
jordan1794's Avatar
Meant to test that earlier before posting, but forgot. Lemme run into the snow and check real quick lol.
Old Jan 28, 2014
jordan1794's Avatar
No result from me pushing on it, but i can't really cause to much vertical movement.
Old Jan 28, 2014
Looking in service information....
There's a service news article about "Got an annoying creak that%u2019s coming from the left or right front of the dashboard or body while going over bumps or when speeding up or slowing down? What you%u2019re hearing are a couple of body seams rubbing together from the upper strut mount area."
Squeak or pop noise.
You would have to locate the source (area) of the noise before seeing if this info would apply to your situation though.
Most all the other info is about pops and clunks.
Old Jan 28, 2014
jordan1794's Avatar
Ok, I'll try to check on the panels and stuff when it gets clearer sometime hopefully in the near future. Thanks for the help.
Old Feb 12, 2014
Couran's Avatar
Couran is an unknown quantity at this point
it sounds like the rubber grommets on your suspension might be dried out. get some transmission fluid and squirt it on them, this should take care of your problem.
Old Feb 12, 2014
Don't do this.
Soaking rubber parts in petroleum products will ruin the rubber.
Use some silicone instead.
Dawit Melese
Oct 4, 2015 08:02 PM
rovafa2002
Sep 28, 2015 06:57 PM
mnewcomb
Air Conditioning
Sep 26, 2015 11:02 PM
emiixo
Exterior
Sep 22, 2015 03:53 AM
TheRiddicles
Sep 21, 2015 01:28 AM
