8th Gen 2006 - 2011.
Replacing 8"" Woofer in 07 Civic EX
Old Oct 6, 2007
yocozuna55's Avatar
yocozuna55 is an unknown quantity at this point
Does anybody know what kind of 8'' sub comes factory installed with the 350 watt system in the EX. I'm thinking about replacing it. Does anybody know the specs???
The sub im looking at...
http://www.futureshop.ca/catalog/pro...083855&catid=#
Is it worth it?
Old Oct 6, 2007
FGCOUPE's Avatar
FGCOUPE is a name known to allFGCOUPE is a name known to allFGCOUPE is a name known to allFGCOUPE is a name known to allFGCOUPE is a name known to allFGCOUPE is a name known to allFGCOUPE is a name known to allFGCOUPE is a name known to all
Re: Replacing 8"" Woofer in 07 Civic EX
simple....
you pretty much said it?
its an 8" subwoofer, but....
i wouldnt say its 350W factory, probably more like 40-50W RMS,
so dont go and think you can jam a sweet 300W 8" sub from Future shop as this may cook your EX amplifier. Youd have to upgrade the amp to go aftermarket for more punch.
Old Oct 7, 2007
dlm's Avatar
dlm
dlm is an unknown quantity at this point
It wouldn't necessarily fry the amp if the subs have the same impedance. You don't want to replace the sub with one that has a lower impedance, it would draw more current from the amp than it was designed to supply.
Anyway, without a more powerful amp it would be pointless to replace just the sub.
Old Oct 7, 2007
zexpoweredem2's Avatar
zexpoweredem2 will become famous soon enough
I was woundering if anyone has installed a aftermarket head unit in a 06-up civic si, the reason that im asking is because im going to be installing a pioneer headunit in my 08 si and i purchased the harness through crutchfield.com and they say that it by passes the factory amp, and sub woofer, i was woundering if anyone has ever installed one and found a way to have the facotry set up work.
Thanks for any help,
Matt
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
mugenca
Apr 16, 2015 12:15 AM
thesushiboy
Apr 12, 2015 02:54 AM
toastyghosty
37
Jun 10, 2002 01:07 AM
ademarco6
Nov 12, 2001 06:52 PM
