8th Gen 2006 - 2011.
Alternator/Big 3 Q's
Old Jan 30, 2007
mrSI11's Avatar
mrSI11 is an unknown quantity at this point
I can't seem to find info on the stock alernator for the 2006 Civic Si. I am installing an audio system, and having those specs would be great.
I also am upgrading the Big 3 even before I start installation on my stereo gear. I think I have located the three wires.....but does anybody have pictures of where they are, or would be able to just explain where they are. Thanks.
Old Jan 31, 2007
speedfoos's Avatar
Did you do a search in the forum on "Big 3"? It something I forget to do all the time.
Here are the locations on an EM2, they should be similar for your Si.
1. battery negative to chassis (under fuse box),
2. chassis (under fuse box) to transmission,
3. engine block to chassis (upper radiator support).
For your alternator, if it helps, my stock EM2 is a whopping 70 amps. I imagine the Si is the same or close to it. Honda likes to interchange as many parts as possible.
Hope that helps a little.
Old Jan 31, 2007
mrSI11's Avatar
thanks for the info. I am going to scope it out tonight when I get home from work.
