q: Engine swap and A/C
Old Apr 16, 2003
HP's Avatar
HP
HP is an unknown quantity at this point
Hi!
A question for you that have done the K20 swap (and everybody else I guess)
How did you do with your A/C? The pulley on the compressor doesn't fit the belt on the K20. You can't get just the pulley, you have to bye the whole damn clutch and everything (not so cheep over here)
Also, are there any problems with the compressor being positioned the other way around?
I haven't really thought about it much because what I did now was to buy a shorter belt and skip the A/C for now.
Thanks in advance
Old Apr 16, 2003
dragoon's Avatar
www.hasport.com may have what you need. they used a/c lines from another car, i think a 92 civic?
Old Apr 17, 2003
HP's Avatar
HP
Yeah, it's not so much the lines I'm worried about. It's the pulley on the compressor that's made for a narrower belt.
Old Apr 17, 2003
solar's Avatar
solar is an unknown quantity at this point
You can swap most pulleys on most compressors, first find the required pulley then take the pulley and compressor to a good A/C shop and have them switch them. BTW most pulleys are incorperated with the A/C clutch so be prepared to spend a little $$$$$.
RicoSuave
May 20, 2015 01:57 AM
cloudguy
Apr 28, 2015 05:02 AM
shawe90
Apr 14, 2015 07:10 PM
robbclark1
Dec 12, 2001 12:18 PM
supercivic01
South
Nov 30, 2001 11:27 AM
