SRI and strut brace
Old Apr 7, 2003
buhatkj's Avatar
buhatkj is an unknown quantity at this point
SRI and strut brace
i have an R1 SRI, which i just installed, and wondered if it would interfere with the future installation of a strut tower brace in the front. for instance, the R1 strut brace for our cars specifically says it wont work with aftermarket intakes. i wondered if anybody had run into this prob before, and could recommend me a manufacturer that makes a brace that will still work with an SRI installed?
Old Apr 7, 2003
Dr5D's Avatar
well DC sports and Nuspeed make one that fits with CAI, so i would asume that ot also works with the SRI
Old Apr 7, 2003
slystad810's Avatar
I would reccomend the Neuspeed. It's around $100 at www.tornactive.com.
Old Apr 8, 2003
CapYoda's Avatar
Escaped Convict
does it have a 90 degree bend rubber adapter at the throttle body??
if so u can probably fit whatever strut bar you want.
lets just say, if anything goes higher than the stock intake system, then it wont fit.
but if it doesn't, it'll be fine.
Old Apr 8, 2003
civicvtec1ps's Avatar
Search and Learn
just get neuspeed front strut bar
Old Apr 9, 2003
luckynumbernine's Avatar
luckynumbernine is an unknown quantity at this point
i agree 100%. neuspeed is the way to go. the bar actually runs up close to the fire wall so it is completely out of the way of the intake. if you own a 2001 5 sp, they give a new nut to remount the clutch fluid reservoir. on my 2002 5 sp i simply had to bend the reservoir bracket forward a little bit. whole install took about thirty minutes. that time includes ****ing around to get the jack out of the trunk. i had to jack up the driver's side to get the bar to fit snug on the bolts. fits like a glove. ( i also purchased mine form tornactive.com. it took 5 days to come from cali to rhode island. very nice.)
Old Apr 9, 2003
Dr5D's Avatar
damn dude, you live in rhode island? thats crazy small! but im sure you hear that all the time.
anywho - there is minor mods needed to fit the nuspeed bar? i thought you could just bolt it right on... please explain
Old Apr 18, 2003
you're correct, rhode island is small. you can drive end to end on i-95 in well under one hour. i used to live in pennsylvania. you can fit 44 rhode islands in one pennsylvania. senseless trivia. but anyway, if you have a manual transmission car you may notice that the clutch fluid reservoir is inconveniently located atop the left front strut tower. if you have an automatic, you need not worry. the neuspeed bar will not clear the reservoir (by fractions of an inch). if you have an 02+, you will need to remove the reservoir from its holder and bend the bracket forward SLIGHTLY. once that is complete, pop the reservoir back in the bracket and you're good to go. this took roughly 5 minutes. 4 minutes to analyze the situation, one minute of actual labor. i also had trouble getting the bar to seat perfectly on the bolts. this is where you need to jack up one side of the car as if you were changing the front tire. i jacked up the driver's side because the passenger's side was against the curb on the street in front of my apartment. with one side off the ground the bar fell nicely into place. the biggest pain in the a$$ was seriously taking all of the crapola out of the trunk and having to go through the routine of jacking up the car. if you own a 2001, neuspeed provides a nut to remount the reservoir in another hole. i think you just need to remove the left front wheel and move the bracket into the forward hole. simple stuff. the dc bar appears to circumvent the clutch fluid reservoir altogther via the numerous bends in the bar. sure, it looks nice under the hood, but it's not too often that i decide to drive with my hood open or completely off for that matter. the neuspeed bar is much cheaper and is much more structurally sound. WHEW! hopes this helps...sorry for rambling....
Old Apr 18, 2003
kjgracing's Avatar
Hail to the king baby
kjgracing will become famous soon enoughkjgracing will become famous soon enough
Yes, go with the Neuspeed one.
You will find that if you are an agressive driver, the torque that makes the engine move will knock against the intake.
Old Apr 18, 2003
xtiszx's Avatar
Cracka
xtiszx is an unknown quantity at this point
it will fit, its VERY tight, i had a r1 intake, and strut bar, the intake once and a while would bump the intake, you just have to angle the strut bar a bit
Old Apr 18, 2003
R3DL1N3's Avatar
wait a second, whats the difference between a strut bar and a strut brace?
Old Apr 19, 2003
RoadRunner's Avatar
strut bar is like a single piece of metal going from strut to strut - like the dc sports one. strut brace - is like the neuspeed
SammySC
121
Apr 7, 2017 07:43 PM
skeener51
Oct 1, 2015 05:56 PM
ken4444
Sep 30, 2015 07:37 PM
Wariogamer
Sep 29, 2015 09:49 AM
meicalnissyen
Suspension
Sep 24, 2015 09:28 PM
