LX to VTEC
Old Apr 7, 2003
AntiAutomatic's Avatar
AntiAutomatic is an unknown quantity at this point
Question LX to VTEC
Hey guys, I am new to the forum and just had a question. I bought an LX civic before I knew how much you need VTEC. So my question is: is it possible to make my 1.7L non-VTEC, VTEC...and if so how much and how hard would it be? Also if it is possible what all is involved?
Thanks
Old Apr 7, 2003
cambo's Avatar
I wish I was asian
lol "how much you need VTEC" hah!
at least u spelled it right tho.
Old Apr 7, 2003
Boosted2k2's Avatar
Boosted2k2 should not be trustedBoosted2k2 should not be trusted
lol.
Don't worry about it, it's nothing but a name on these engines
Old Apr 7, 2003
born2xLr8's Avatar
Lots of people say that they can't even tell the difference between a SOHC and a VTEC. Like the others said, you don't "need" it. I wouldn't worry about it.
Old Apr 7, 2003
NeonImpact's Avatar
Forum Sponsor
what you talking about foo..
my VTEC added 45 HP to the wheels..
But in an answer, i wouldnt bother doing it man, its really no difference..
13 hp is the difference but it doesnt matter..
Old Apr 7, 2003
CivicLX620's Avatar
CivicLX620 is an unknown quantity at this point
born2xLr8, correct me if I am wrong, but arent all 7thgen's SOHC engines???
Joel
Old Apr 7, 2003
Obsidian's Avatar
Obsidian is an unknown quantity at this point
On 7th gens, the EX models usually have Vtec. LX and DX don't. Again, Vtec isn't all its cracked up to be.
Old Apr 7, 2003
Project2k2's Avatar
Ummm all the 7th gens excluding the Si are SOHC.....Ex VTEC and all the others non-VTEC. For 13 hp it's pretty crappy. Now it would be different if they offered a DOHC for the EX. That would be one bad machine
Old Apr 7, 2003
MangoEX's Avatar
Just Be
MangoEX should not be trusted
You guys are just jealous cause you got the black-mirrored LX I drove my friends' LXs, and with the VTEC, you can definitely feel it in higher RPMs -- not strong, but nonetheless, still there. It helps save gas to. Every bit helps right? Lets say you LX guys had the ability with the flip of a magic switch on your dashboard to turn on VTEC, you mean to tell me you'd rather leave it off?
Old Apr 7, 2003
Drew2k1Civ's Avatar
Drew2k1Civ is an unknown quantity at this point
I think VTEC is a must. I just got my head swapped from an LX head to en EX head so I could have it. I also agree with the guy that said that every lil bit helps. If your racing, that extra 13 hp or whatever it is might make the difference in gettin spanked or not.
Old Apr 7, 2003
Drew2k1Civ's Avatar
But to actually answer your question Anti, yes it is possible to make an LX VTEC. You have to get an EX head, EX ECU and run a oil line to the VTEC solenoid.
Old Apr 7, 2003
Boilermaker1's Avatar
Jap-Euro Fusion
The Si VTEC is nothing to cheer about either. The Si makes the 160 HP from the 2.0L displacement. For all intents and purposes, the timing is fixed.... Why you ask?
The i-VTEC in the K20A3 is intake only. And of the variable intake timing, only 1 valve is variable.
One intake valve always follows the primary cam profile, the second one follows a secondary whimpy cam profile until 2300 RPM and then shifts to follow the Primary cam. Exhaust timing is fixed. That's it. Totally useless, no extra power. Some people say the Si bombed for this reason... I'd tend to agree... it's a step back from the B16A beast from 99 and 2000.
Meanwhile EX VTEC is intake only, but it varies the timing of both intake valves and it does so to add extra high end power. Both intake valves follow the lower profile until roughly 4500 RPM (everyone always argues this... so say somewhere between 4100 and 4800) when they both shift to the high cam profile.
You want manly man's VTEC, get a K20A2 from an RSX Type S and swap it... that'll give you the fabled VTEC where both the exhaust and intake are variable, giving it the rediculous redline and high end power that VTEC engines are known for.
Old Apr 7, 2003
Dr5D's Avatar
just changing the head would not change your car to vtec!!!! i hope you are not telling people that!!!! you think you can get aprox 13hp from just a header on out car?
to change it over to vtec its probably better just to go get one with it fromthe factory
Old Apr 7, 2003
jwsisme's Avatar
jwsisme is an unknown quantity at this point
Which 7thGen LX model doesn't have VTEC?
Old Apr 7, 2003
CivicRookie's Avatar
Jeremy's Iron
CivicRookie is an unknown quantity at this point
Um, ALL LX models don't have VTEC..
Old Apr 7, 2003
stl01civic's Avatar
BOOSTED DOHC i-VTEC
stl01civic is an unknown quantity at this point
All LX does not come with VTEC
Old Apr 8, 2003
RiceRocketeer's Avatar
Custom Titles are played out
RiceRocketeer has a spectacular aura aboutRiceRocketeer has a spectacular aura aboutRiceRocketeer has a spectacular aura about
Hmm, Just so everyone knows the HX model is VTEC... With the same amount of HP as the LX and DX..
DX- SOHC Engine, with no power. 115 HP Engine
HX- SOHC VTEC Engine, with some power but no sunroof, 115 HP Engine
LX- SOHC Engine, with all power but no sunroof, 115 HP Engine
EX- SOHC VTEC Engine, with all power, sunroof, and 127 HP Engine.
Sorry, but no one was saying the HX, and that is a car they sell, I almost got one, but wanted the power features, and at the time didn't really know or care too much what VTEC meant, and now that I know I like my Non-VTEC civic better.
I heard Non-VTEC's are easier to Turbo than VTECs... just something I heard... No offense to the VTEC owners.
RiceRocketeer
Old Apr 8, 2003
Dr5D's Avatar
so if you are saying that both the HX and the EX have vtec, then what gets the extra 13 on the EX? better vtec or what? or maybe your confused? how come the vtec didnt make the HX have more hp???
Old Apr 8, 2003
greatcasa's Avatar
greatcasa is an unknown quantity at this point
All the 7th gen vic's are SOHC
Old Apr 8, 2003
greatcasa's Avatar
Simply swapping the heads does not give you VTEC. Its a much more lengthy and involved process than that and for the time and money you might as well do a K20 swap.
Old Apr 8, 2003
greatcasa's Avatar
There is only one LX model, and no it does not have VTEC
Old Apr 8, 2003
c1v1c's Avatar
c1v1c is an unknown quantity at this point
i have a lx nonvtec i want to make my civic vtec, is it possible, if you can how much will the vtec head cost me . and is it worth it.
Old Apr 8, 2003
greatcasa's Avatar
RiceRocketeer
Not true. The HX has 117.
Old Apr 8, 2003
sadboy916's Avatar
HISPAnIC CAUSIn PAnIC
WHO CARES VTEC SUCKS
i still dont know why people make a big deal about it like its a turbo or supercharger. if you want a fast car why buy a honda. LS1 ownes i cant wait to get my hands on a firebird formula
Old Apr 8, 2003
greatcasa's Avatar
Again LX's, there is only one kind and its not VTEC. No it is definitely not worth trying to change over to VTEC, and is not cost effective. Just be happy with your non-VTEC LX engine. Its just as good as all the other 7 gen vic's
Old Apr 8, 2003
thanks for the feedback, but you didn't answer the question really.
Old Apr 8, 2003
greatcasa's Avatar
I didn't say the cost because one I don't know (read an estimate in another thread: close to or over the cost of a K20 swap), and two I didn't bother to find out because like I said its completely worthless to even consider that project. You might as well buy a used EX engine, exhaust system, and ECU from Japan.
Old Apr 8, 2003
sadboy916's Avatar
you can get a ex engine for like $600. i say go for it and report back to use on how much you like your new "performance" engine lol lol lol lol lol lol muhahahahahahahahahaha
Old Apr 8, 2003
Southpaw7883's Avatar
Southpaw7883 is an unknown quantity at this point
yo does anyone even know what they talkin bout? lol, i mean seriously...peace...southpaw...o and for the non math dudes and dudettes, its 12 hp difference...
Old Apr 8, 2003
greatcasa's Avatar
Please translate
