Old Mar 13, 2003
Dr5D's Avatar
Ghost Writing
I just finished getting the 'civic' off my car and I did the gooe gone and there is still a problem.
you can see where the letters used to be, and it dosent look like its cause of paint fade, just not quite all the glue is gone. what can i do to fix it???
i think ill go take pics soon and post them here too
Old Mar 13, 2003
mykungfuisthebest's Avatar
mykungfuisthebest is an unknown quantity at this point
try acetone, dont leave it on paint to long though... ibtm
Old Mar 13, 2003
Dr5D's Avatar
whats acetone? where do you get it?
Old Mar 13, 2003
born2xLr8's Avatar
Better yet, try waxing that area. If that doesn't do it, do a search on the subject. I'm positive it's been discussed before. You'll probably find the answer in your search.
Old Mar 13, 2003
Dr5D's Avatar
you cant see it real well in the pictures, but when you look at it in real life its more apparent, the pics give an idea tho
Edit:
Pictures removed.
Old Mar 13, 2003
Dr5D's Avatar
Quote
[hr]Originally posted by: born2xLr8
Better yet, try waxing that area. If that doesn't do it, do a search on the subject. I'm positive it's been discussed before. You'll probably find the answer in your search.[hr]
I thought of wax, but dosent that just seal everything in? cause thats not want I want. and i did search, extensively, and didnt really find anything too helpful.
i was thinking of a clay bar, but i have no idea how to use one or where to get it even.
Old Mar 13, 2003
greatcasa's Avatar
greatcasa is an unknown quantity at this point
Quote
[hr]Originally posted by: Dr5D
whats acetone? where do you get it?[hr]
Acetone that can be bought by the public is better known as nail polish remover. Nail polish remover is just watered down acetone. Just like rubbing alcohol is watered down isopropyl alcohol. So in reality nail polish remover is probably safer than straight acetone. And like already said, don't leave it on too long. Long periods of exposure have been known to disolve some paints (hence nail polish remover). Hope this helps
Old Mar 13, 2003
Boosted2k2's Avatar
Boosted2k2 should not be trustedBoosted2k2 should not be trusted
use wd-40!
Old Mar 14, 2003
reytito's Avatar
no don't use ACETONE man..you'l weaken the enamel inthat area. keep using goo gone...and let it sit for alittle longer. Try wiping again, but if not try using your nails with a cloth over them, to gently pick pick pick. it really should just come off easy with an extended sitting with goo gone on them.
Old Mar 14, 2003
Dr5D's Avatar
first i tryed a hair dryer, didnt work so well - then wd 40, didnt work real goo deither - then i got some gooe gone from the stor and this is what i ended up with! i did GG like 3 or 4 times! the last time i did it i left it there for like over an hour!
also i niticed that my fingernails left some small scratches in that area[IMG]i/expressions/face-icon-small-nono.gif[/IMG]
