Trust e-Manager
One of few in the 13's
THE E-MANAGE IS AMAZING!!! I have it on my turboed Lx... and it's outstanding... You can control fuel maps, V-tec, Ignition and alot more crap... I personally think (Along with many other mechanics) That it's better than the AEM EMS... trust me... Greddy went over the top on this one...
Well worth the money!
I am pretty sure you can controle Vtec... I have an Lx so I am not using it for that. If you can control vtec like I think you can, you probably can go more in depth with the e-managa then with the super-afc. The going price for the e-manage is $300... But I would suggest you get the support tool with it if you are not planning to run it with the Greddy Profec e-01 boost controler. Plus you can upgrade it by buying different harnesses I.E: Ignition, fuel pressure etc... Check the web site for more details.
Off of GReddy's website....
Quote
[hr] e-Manage is an inexpensive programmable fuel management system that allows you to properly tune your factory fuel system, without having to change the entire factory ECU system to an expensive "stand-alone" unit. The e-Manage system is a universal "piggy-back" type unit, which taps into most factory ECU wiring and it still utilizes the existing sensors. Basic functions will allow the user to slightly alter factory injector duty-cycle(± 20% at 5 preset RPM points), by intercepting and altering airflow or MAP sensor signals. For VTEC cars you can adjust the VTEC shift point.
Additional features that are built into the system, but are only accessible though the use of our PC-Windows based "e-Manage Support Tool" communication software (Please see our Authorized GReddy Support Dealers for more information) are a 16x16 Airflow Adjustmemt Map, Larger Main Injector correction adjustment, Upgrade Air Flow Meter adjustment, Boost Limiter Cut, Anti-engine Stall, VTEC-fuel adjustment, Real-time Map Trace, Real-time Display, Real-time Communication, and basic Data-logging.
With the use of our "Optional Injector Harness" and the software, the unit has the ability to control an additional 16x16 Injector duty cycle Map and the Controls for adding up to 2 Addional Sub-injectors. If the "Optional Ignition Harrness" and the software is used the unit has the ability to control a 16x16 Ignition Timing Map. All of the above Maps can also be Map-traced in Real-time as well. If the factory range of Map or Airflow meter is surpassed, you can incorperate our "Optional GReddy Pressure Sensor and Pressue Harness" to set larger scales of ajustment.
All installation and tuning should only be made by a trained techntion with proper Air/Fuel Monitoring tools.
Part # Description List Price
15500550 e-Manage (main unit) $379.00
15500901 Optional Injector Harness $38.50
15500902 Optional Ignition Harness $41.80
16401301 GReddy Pressure Sensor $120.00
16401406 Pressure Sensor Harness $35.00
TBA e-Manage Support Tool see AGSD[hr]
solarpunk70
Apr 12, 2016 11:43 AM
deanaZoom
35
Sep 19, 2015 12:22 PM
0396
Aug 21, 2015 05:27 PM
