How to install air/fuel gauge
Old Mar 9, 2003
lucky13matt's Avatar
lucky13matt is an unknown quantity at this point
I have the instructions from autometer but, i can not find the wires, so can someone send me the diagram or something, thanks
Old Mar 9, 2003
jamesbbh's Avatar
jamesbbh is an unknown quantity at this point
its the wire harness on the first o2 sensor on your header and youre going to want to do it before the grey harness,,,,, not right next to the sensor but on the other side of the connection harness. theres going to be a white wire with a black stripe and just tap into that
Old Mar 9, 2003
iluvbritney's Avatar
iluvbritney is an unknown quantity at this point
i prefer you take it to the shop and have them do it, or at least ask them for more info. or u can have it on just for the look [IMG]i/expressions/face-icon-small-tongue.gif[/IMG]
Old Mar 9, 2003
Boilermaker1's Avatar
Jap-Euro Fusion
Between the sensor and the plug, tap the black wire. The green/yellow stripe wire from the cig lighter will give you 12V and you can ground it to any known ground. Mine is grounded to the engine block (front right corner, you'll see the strap running to the frame), put a ring terminal on the wire, undo the ground bolt, add your wire and bolt it back down. Make sure you have both wires in there.... your engine must remain grounded.
Old Mar 10, 2003
leleboy's Avatar
leleboy is an unknown quantity at this point
[IMG]i/expressions/face-icon-small-smile.gif[/IMG] i ran a wire from the o2 sensor on the hedders to the hole in the firewall under the glovebox, then up under the dash, all the way to the drivers airvent, where i mounted the gauge in to.i took a probeing light pointy thinggy, and found the ground and the 12v ignishon wire from wires that are pluged into the gauge cluster. tapped in and it was the black wire, of the four, from the o2 sensor.
user 84948
Air Conditioning
40
Jul 10, 2015 07:08 PM
juror
May 26, 2015 06:35 PM
manicEL
Dec 10, 2001 06:33 PM
AlphaInfinity
Nov 21, 2001 03:15 PM
meels808
Nov 9, 2001 03:08 PM
