**HELP** WITH TYC AIMING...
Old Mar 7, 2003
FALKEN's Avatar
Civicforums Junkie
TYC AIMING...
*LOOKING AT THE HOUSING FROM THE BACK*
FOR THE PROJECTORS:
which screw is for the up/down aiming...
which screw is for the right/left aiming...
FOR THE HIGH BEAMS:
and how in the hell can i get my hand in there??
**DID A SEARCH...NOTHING**...AND THE HOUSINGS DIDN'T HAVE DIRECTIONS
Old Mar 7, 2003
blackbullet's Avatar
The Legend
I'd like to know also. Mine are still a little off.
Old Mar 7, 2003
BlueFlame's Avatar
BlueFlame is an unknown quantity at this point
The easiest way to adjust them is to take the battery out (left side) and pull out the washer fluid resevoir (right side) and then use a socket wrench with I believe it's a 10mm socket.
I have no idea which screw does what, but mine are horribly mis-aligned as well, and I didn't even see screws for the projectors, so they're aimed really low. My hi-beams aren't much higher than my low-beams so if someone does know which screw does what, I'd be grateful as well.
Old Mar 7, 2003
AzNmiKex215's Avatar
2k1civic.com O. G.
u really just have to play with it. my highbeams and low beams came aligned pretty well. just my low beams are a little too low. andi think the best way to adjust it is u have to have it free from the car. aka removing thebumper and bolts etc. its hard has hell to fit a socket wrench and turn it enuff to actually see anykind of results allowing u to figure out which screw does what.
mines are also fogging since i opened them. need to reseal them better too.. weather hasnt been cooperatiing
Old Mar 7, 2003
FALKEN's Avatar
Civicforums Junkie
maybe i should just take them out and get them 'straight' in the hole first...and then fine tune them afterwards...
BTW...even though they are mis-aligned...they are VERY bright
Old Mar 7, 2003
jkim1978's Avatar
jkim1978 is an unknown quantity at this point
questions about the tyc... some people say its not bright... its horrible in the dark... and some people say its alright... which is it? cause i wanna get them too... but if its not that bright... then i would stick with the stock ones... but if they are bright i wanna get them... so are they bright? and if they are not bright... how unbright is the tyc... compared to stock ones. 20% 10% 5%... meaning is it noticeable unbright? thanks...
Old Mar 7, 2003
FALKEN's Avatar
Civicforums Junkie
mine are mis-aligned right now but they are very bright compared to the stocks...
Old Mar 7, 2003
2k1civic.com O. G.
i would definitly say they are a positive improvement over stock brightness
Old Mar 7, 2003
HondaSales's Avatar
HondaSales is a glorious beacon of lightHondaSales is a glorious beacon of lightHondaSales is a glorious beacon of lightHondaSales is a glorious beacon of lightHondaSales is a glorious beacon of light
there is no way that the tyc's are brighter than the stock headlights. unless i am using the wrong bulb???
i have the piaa xtreme white in there. anyone have any suggestions? when i had the stock assembly, i was using piaa xtreme white also and i would say they were about 20-30% brighter. right now i feel like i am sacrificing function for looks. they are aimed a little low, maybe that's the problem???
Old Mar 7, 2003
jkim1978's Avatar
so we have another mixed opinions.... [IMG]i/expressions/face-icon-small-sad.gif[/IMG] so overall you think its worth getting it... ? if it like little less brighter then the stock ones... i could deal with that... but if its really bad as some people are saying it is.... then its really bad... what do you guys think...
Old Mar 7, 2003
Weaponx12o's Avatar
mine are a little off but i got lazy after i installed them so i left it the way they are hehe. i think i blind on coming traffic [IMG]i/expressions/laugh2.gif[/IMG]
Old Mar 7, 2003
Dr5D's Avatar
i just got my TYCs in the mail today actually, but the projectors i have now are bright cept when i put it next to connies civic with stock lights (dont kow what bulbs, maybe stock?) his seemed brighter but i think its cause they are not as focused as the projectors, IMO
Old Mar 7, 2003
Weaponx12o's Avatar
yea, the TYCs seem dimmer than stock to me. but maybe its just me? [IMG]i/expressions/face-icon-small-confused.gif[/IMG]
Old Mar 9, 2003
Hondasport2k3's Avatar
i gOt da MaJik stiK
Hondasport2k3 is an unknown quantity at this point
Cant see s**t with JDM projectors or any projector. I like the blue lens look though. Plus I have fogs which help so angeleye is for the look.
Old Mar 10, 2003
FALKEN's Avatar
Civicforums Junkie
ok...I aimed them last night and they have one awesome beam pattern......
with the 'stock' TYC bulbs I wanted to compare to 'stock' Honda H4's...so what i did was, parked my wife's 02 sedan next to my 01 sedan, turned on the lights to both vehicles and the TYC's actually over-powered the stocks...now I hear a lot about them not being an improvement over stock, but I would have to disagree...
now for an upgraded set of bulbs...
pdxbiker
Jul 11, 2002 07:13 PM
Player1
Jul 8, 2002 11:49 PM
FlippedOut
Jun 19, 2002 12:16 AM
GuSTo
Jun 18, 2002 01:50 PM
marux
Feb 22, 2002 02:06 PM
