old Clear headlight question, ><
Old Feb 6, 2003
Cider's Avatar
Cider is an unknown quantity at this point
I have searched....read all the arcticles.... read the diy...
i removed the bumper by removing 4 tip + 2 screw (it kinda lean forward...)
Q1. how much does it suppose to lean forward? i was kinda a weak guy @@...
and it jus barely got about a few cm from the headlight.. should i pull more?
.. then i remove the screw/bolt , 2 of them , on top of the headlight...
then i remove the 2 tip for the fenders (**** i broke a tip)
Q2. where should i buy one replaced &gt;&lt;?
then.. i saw one bolt have to be removed in side teh fender (tire well?)
Q3. and i had no idea where the 4th one is...
and it was scary for me on the way "breaking" the car alone...T_T
sorry i was kinda really really a newbie and this is my first tried &gt;.&lt;
can anyone pleaes kindly help? Thank you very much in advanced
Old Feb 6, 2003
sg2kca's Avatar
sg2kca is an unknown quantity at this point
Q1 = It leans just enough for you to be able to get the 10mm bolt under the headlight
Q2 = You broke a tip? do you mean clip? If so you could get them at the dealer for like 50 cents
Q3 = The forth bolt is right infront of the headlight, lean down and you should be able to see it
If worse come to worse, it ain't that hard to remove the whole bumper, it'll probably make it easier for you too.
Gook luck
Old Feb 6, 2003
alphabios's Avatar
alphabios is an unknown quantity at this point
I would recommend removing the whole bumper, it will really make it easier overall
JustaRhymez
General 7th Gen
Jul 10, 2015 07:12 AM
Ccoop87
Jul 9, 2015 03:26 PM
BootyDo
Jul 7, 2015 06:06 AM
Dagooseisloose
Nov 9, 2001 10:18 AM
CivicBR900EX
Sep 5, 2001 10:27 PM
