HELP!!!
HELP!!!
alright, so i go to install my front Konis, and i can't get the steering arm out of the strut assembly!!! i've tried everything, and i'm afraid that i've really messed things up cause i deformed the bolt by banging on it. it just won't come off. tried hammering, hammering with wd40, twisting, turning, everything. someone please help!
no, not bent, just messed the threads up, although i'm not sure it matters cause that thing is not going anywhere, i don't even need the damn nut on there. any suggestions are appreciated.
don't have access to a camera right now, but i'll try to explain. on the strut assembly, there is the arm that comes off of it. that arm connects to the steering control arms. the steering control arm is connected to the strut assembly by a bolt that goes down through a hole in the arm that comes off the strut assembly. it's this bolt that is attached to the steering arm that won't come free of the strut assembly, even though it's supposed to easily come out. hope that helps a bit, grey.
DIY King
Oh, that one. There is a little pin in that bolt. Did you take that out? [IMG]i/expressions/face-icon-small-confused.gif[/IMG]
At least I think there is, if I remember correctly.
you need to hammer the end of the tie rod not the bolt man,try hooking back the nut to the bolt for a little support for the tie rod and give the hammer some force but make sure to hit the end tha will come loose
hope that helps
hope that helps
DIY King
Oh, wait. The tie rod? Yeah, the best tool is a tie rod seperator. A U-shaped tool that applies pressure around the tie rod to get it out. I think that's what should be used...
bolt goes through hole in arm on strut assembly. tie rod is connected to bolt. how do i get the tie rod off the bolt then? pictures would be appreciated, i'm so lost now. i just want to do my struts, but i'm prepared to go to the shop tomorrow and have them mess with it.
Quote
[hr]Originally posted by: Pinoy3LeR
hope that helps
[hr]
hope that helps
[hr]
When you are doin anything with the suspension assembly never play with the bolt head. It cna strip or break off. You will see that you cna move that "arm" so move it ina direction where you cna get a good angle at it from the other end of the bolt and hammer away. USE SOME FORCE!!!!!!!!!!!!!! I mean that too!
