dry nitous system
Old Nov 11, 2002
chefjnr's Avatar
chefjnr is an unknown quantity at this point
dry nitous system
getting the nx 50 shot dry system, what else do I need to do to my car to prep for it?? I got the headers, hi flow cat and full exhaust. Bosch platinum+4 plugs, cold air intake, aem adjustable cam gear. What is the danger of running lean on a 50 shot dry system?? Should I look at putting on a adjustable fuel regulator and bumping up the pressure a bit??
If anyone installed one of these on their 2001 civic ex, please pm me with some info, thanks!!!
Old Nov 11, 2002
LudlamTheory's Avatar
i boogie for the raindrops
i thought we needed wet kits for our cars..., due to no return fuel system
Old Nov 11, 2002
Intruder's Avatar
Intruder is an unknown quantity at this point
nx is a wet kit, do some research on this please.
Old Nov 11, 2002
PlatCruiser's Avatar
PlatCruiser is an unknown quantity at this point
put the nitrous kit away before you hurt yourself [IMG]i/expressions/laugh2.gif[/IMG][IMG]i/expressions/laugh2.gif[/IMG][IMG]i/expressions/laugh2.gif[/IMG]
Old Nov 11, 2002
HondaGuru's Avatar
From: San Diego, California, USA, Northern Hemisphere, Earth, Sol System, Spiral arm of the Milkey Way
HondaGuru is an unknown quantity at this point
OEFFINGELL!
A) NX makes both wet and dry kits.
and
B) PLATNUM/IRIDIUM PLUGS ARE NOT GOOD FOR NITROUS AND/OR FI APPLICATIONS.
Get NGK-BKR7E plugs. They are available from most import shops or you can order them from summitracing.com. I pay 10 bucks for a set of four plugs. Iridium plugs will melt and cause serioius internal problems to your engine when it does. Gap the plugs to stock specifications before installing.
http://home.nycap.rr.com/ghjrsc/spark_plugs.html
Old Nov 11, 2002
chefjnr's Avatar
sorry, it is the NEX kit. They say it is useable, it feeds right into the air intake. I'm not asking for opinions on wether I should or shouldnt by people that dont have it, I am asking for advice from people that DO have it and how they did their set-up.
Old Nov 11, 2002
HondaGuru's Avatar
NEX makes coilovers, ZEX makes nitrous systems.
ZEX is non upgradable. You wont be able to make it wet, and that directly effects the ammount of nitrous you can safely run... plus its purple, and made in france
i HIGHLY reccomend NX or NOS nitrous. And yes, this is coming from a veteran nitrous user.
Old Nov 12, 2002
chefjnr's Avatar
sorry about the confusion on the brand, I went with a nitrous express stage 1 kit, (50 shot nozzles), remote bottle opener and bottle warmer, is anything else needed that the kit does not come with or the other items i mentioned???
Old Nov 12, 2002
SMX's Avatar
SMX
SMX is on a distinguished road
A window switch so you can control the rpm range where you spray.
Old Nov 12, 2002
HondaGuru's Avatar
that too, however its not necessary.
Old Nov 12, 2002
HondaGuru's Avatar
also find out if the kit comes with a throttle mounted micro switch. if it doest BUY ONE. NOS nitrous makes one for like 15 bucks. u can order it at summitracing.com as I did.
Old Nov 12, 2002
JDM1982's Avatar
JDM1982 is an unknown quantity at this point
The NX kit comes with everything you need, wot switch (full throttle) all the wiring and connectors that you need, it also comes with a activation switch but it is cheap. The kit that is made for our cars is wet. As far as Zex they will have a wet kit out later next year. If you have any questions about the kit just email me. Hope this helped you out.
SimpleUser
Apr 24, 2021 02:54 AM
mjdiaz89
Jun 21, 2016 09:26 PM
liagreenhalgh92
Jul 21, 2015 01:31 PM
hoofboy
Jul 17, 2015 04:27 PM
Hqly2001
22
Jul 12, 2015 06:44 PM
