Need help with my HP header
Old Oct 16, 2002
NBPCivic's Avatar
NBPCivic is an unknown quantity at this point
I put the HP header and hi flow cat on this past weekend and noew there is a whistling sound coming from somewhere. I am pretty sure it is where the header and cat bolt up together. I put a new gasket from honda in there but it is still making the noise. The problem is that the header and cat don't meet up perfectly parallel and there is a larger gap between where they meet on the top than there is on the bottom. Can anypne give me some suggestions on what I should do to fix this? Thanks
Old Oct 16, 2002
Desi's Avatar
Desi is an unknown quantity at this point
you can try a gasket sealer. if the pipes aren't lined up together, there's probably air seeping through. but that's my suggestion. i could be wrong though.
Old Oct 16, 2002
nbpEMCivic's Avatar
nbpEMCivic is an unknown quantity at this point
You have an exhaust leak. I have the same problem after messing with my exhaust. Re-do the connection where you think the leak is at.
UltraHDGames
Jun 8, 2016 05:16 PM
HondaGuy7
Feb 22, 2016 01:00 PM
ThatGuy913
Nov 9, 2015 06:31 AM
jdh022764
18
Nov 3, 2015 06:44 AM
anubis62
Sep 27, 2015 12:56 AM
